Go Back   Automotive Forums Car Chat > Pontiac > Fiero
Old 07-23-2005, 06:36 PM
scorpian scorpian is offline
Question help with temp gauge
1986 GT. The temperature gauge is not responding. It moves when I put the ignition on but stays indicating cold even when the engine is hot. I located the temperature sensor switch on the front left side of the manifold just below the ignition coil that when grounded activates the temperature idiot light on the dash. The solid green wire. It also has a green/white with it that seems to do nothing.Where is the temperature sensor that grounds the temperature gauge. Can you help?
Old 07-24-2005, 06:29 PM
84fiero123's Avatar
84fiero123 84fiero123 is offline
Re: help with temp gauge
under gooseneck for thermostat. one single green wire with a white stripe, is for temp guage.
technology is great when it works
but one big pain in the ass when it doesn't
Detroit Iron Rules, all the rest are just toys!
Old 07-28-2005, 06:01 PM
Re: Re: help with temp gauge
Thanks...turns out that one is the switch for the fresh air blower on the alternator and the ignition coil. I found the temp gauge sensor is the same as the idiot light switch. The second wire was the gauge one, there was a break in the wire just before the connector. I finally fixed it. I appreciate your help. I will most likely be back in the near future with more questions.
