Go Back   Automotive Forums Car Chat > Isuzu > Amigo
Old 07-23-2005, 06:35 PM
Shaffer Shaffer is offline
98 Amigo Parking Brake
The parking brake on my Amigo isn't strong enough to stop the vehicle from rolling. I have never dealt with a parking brake before. What is involved in fixing it?
Thanks.
Old 08-16-2005, 05:24 PM
TigrrrLily TigrrrLily is offline
Re: 98 Amigo Parking Brake
Rear discs or drums?
Thanks.
Old 08-16-2005, 07:23 PM
amigo-2k amigo-2k is offline
Isuzu Guy
this is from my manual for a 4x4
Parking Brake Adjustment
1. Prior to lever stroke adjustment, adjust rear brake
shoe/rotor (drum) gap. Perform this procedure with
loosening the adjust nut of the hand brake lever.
2. Remove the adjusting hole plug (rubber) and turn the
shoe adjusting screw downward with a small
screwdriver so that shoes will expand until they get
into close touch with the rotor. (Turn down the
adjusting screw notch by notch until the rotor does not
turn.)
3.Turn the adjusting screw in the opposite direction
(upward) until the rotor can be turned lightly. Standard
number of notches to turn upward: 7 or 8
Turn the rotor and make sure that there is no brake
dragging.
4. After the rear brake shoe/rotor (drum) gap has been
adjusted, perform parking brake cable adjustment.
5.Turn the adjusting nut so that the parking brake lever
travels 6–8 notches when pulled up with a force of 30
kg (66 lb).
6. Make sure there is no brake dragging. Then tighten
the cable lock nut
Torque : 13 N·m (113 lb in)
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
