Old 07-23-2005, 03:48 PM
ulremember ulremember is offline
1990 Caravan Tranny Replacement
Does anyone out there have ANY tips on getting this tranny back in. I am/was trying to use a standard floorjack. What fun. two hours trying, no luck. I am going to get a tranny jack and try that. Are there any more tips and hints that I may need to know about?
Any tips are appreciated!
Thank you in advance!
ulremember
[email protected]
Old 07-23-2005, 08:41 PM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 1990 Caravan Tranny Replacement
Chances are that the transmission jack will give you a lot more control than the floor jack. It should be pretty easy to get it back into position although clearance is minimal. Once you have the bell housing centered just below the flywheel with about a half inch clearance it should jack into place easily.
Old 07-24-2005, 07:02 PM
lon lon is offline
Another option
lift from top by a long thread rod, someone using cherry picker too.
Old 07-25-2005, 01:26 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
another way you can do it with a floor jack is get some bricks on top of the jack pad and use that to move it around. You also can tilt the engine down slightly so that you can access the the bellhousing bolts a little better. You'll need a second person to steady to transmission so that it won't fall off.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 07-25-2005, 01:25 PM
Thank you
Thank yous to all that replied. Got a "transmission jack" adapter from local tool supply. Gotta raise the van now. This is a job that will not be repeated !
Thank you all again!
Chuck
