Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-23-2005, 01:08 PM
scottm1981 scottm1981 is offline
94 cutlass 3.4 wont start
Ok it was running fine, parked it, came out next morning and tried to start it and it turns over but will not start. i can hear the fuel pump and i sprayed a little starting fluid in the carb and still nothing, i dont know anything about this but i assume its electrical, any help would be appreciated. thanks
Old 07-24-2005, 03:24 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 94 cutlass 3.4 wont start
Pull a spark plug out, connect it's spark plug wire and ground the threads on something metal, have somebody else try to start the motor, observe the spark plug for "spark" when you try to start the motor?
What happens?
Old 07-24-2005, 03:29 PM
ok i just got done changing the front 3 plugs, and i couldnt get to the back 3, but i tried to start it up with just the front changed and it started right up. so it seems that it was the plugs and wires. Now i just need help on how to get the back 3 changed. thanks
Old 07-24-2005, 03:33 PM
AF - Advisor
People tell me to disconnect the dog bone (top motor mount) and with the shifter in park, pull the car toward you to rock the entire motor over to access the back cylinders.
Old 07-24-2005, 03:36 PM
yes that is what i read also, but i tried pulling as hard as i could get and there was no way i had enough room, i even tried a crow bar and still no luck.
Old 07-24-2005, 03:53 PM
AF - Advisor
With the parking brake set, try your crowbar with the trans in neutral.
Old 07-24-2005, 03:55 PM
Ok i will try that. thanks
Old 07-25-2005, 08:11 AM
Manny_boy's Avatar
Manny_boy Manny_boy is offline
Please don't try to rock your 3.4 forward, they don't, unless your lower mount is shot. The roll instructions are for the 3.1 engine not the 3.4.
