Old 07-23-2005, 11:45 AM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
my 4 headlight mod quit?? help?
ok i did the mod where you ground 1 wire from under the relay center and it has worked fine no problems at all and just the other night i was driving and the dims shut off leaving only the brights on, they still work by them selves but not together. and the wire is still grounded solid and i soldered it under the relay center. any ideas it sux not having this now.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 07-23-2005, 06:45 PM
99redsilverado's Avatar
99redsilverado 99redsilverado is offline
Re: my 4 headlight mod quit?? help?
double check your connections, then check them again...if it still doesnt work, return it to stock, then re do it.....theres not much that can go wrong...except for loose connections
'99 Silverado 4 x 4
bunch of goodies
Old 07-23-2005, 08:38 PM
thats what i thought , i will have to pull the relay center back out and checkit when i get some time.
Old 07-25-2005, 12:14 PM
i found the problem, i put a fuse on the wire and it was only a 5 amp and it was pulling to much ground so it popped, i upgaded it to a 10 and its working fine. so i can see clearly again. haha
Old 07-25-2005, 11:58 PM
constructive question.....whats the fuse going to protect....the ground wire is not hot...you cant over ground something or burn something up by grounding it.....id bypass the fuse completely...
'99 Silverado 4 x 4
bunch of goodies
