Old 07-23-2005, 08:58 AM
bowhuntrr bowhuntrr is offline
vibration
I have 2 2004 silverados ext cabs they both have a vibration between 37-43 mph and 67-72 mph. the dealer has changed rims and tires. does not help.
anybody having this problem?
Old 07-23-2005, 03:23 PM
ColoradoSilverado ColoradoSilverado is offline
Re: vibration
Hi bowhuntrr, if you ever find out what the problem is please let me know, I have a similar problem. After I had my wheels balanced it was gone for a week but now it's back again.
Bert
Old 07-25-2005, 09:25 AM
sportin83 sportin83 is offline
Send a message via AIM to sportin83 Send a message via Yahoo to sportin83
ive got a 2002 ext cab and it had that vibration with the stock wheels and i bought new wheels and it still has is. i dont know what it is, ive check bolts and joints and bushing and i see nothing that is bad. its kinda annoying but ive learned to live with it.
2002 CHEVY SILVERADO
more pics at http://www.cardomain.com/ride/2228127
Old 07-27-2005, 10:39 AM
geneb11's Avatar
geneb11 geneb11 is offline
I found this link in the forum about the front drive shaft spinning in 2wd on trucks with autotrac and that the spinning is normal.This would explain the vibration.I am also getting a slight vibration.Maybe I'll change out the U-Joints with greaseable joints.
http://www.automotiveforums.com/vbul...highlight=lift
2000 Chevy Silverado LS
3dr 4x4 5.3 Vortec
Old 07-27-2005, 07:11 PM
budone budone is offline
2005 Silverado Vibration
I am printing this thread off for the dealership. I have had three balances, two rotations, 2 alignments. The vibration leaves only for a short time and it comes back.
Mine is between 57-63mph
Old 07-31-2005, 06:59 PM
I saw a sign in one of the local AutoZone's that said about cv joints, how to tell if they're worn. 1, vibration at high speed 2, popping at low speed turning. I wonder if this could be it, my truck has 106K miles on it. I had the front wheels balanced and the vibration was almost gone for about a week. I wonder if a balancing cancels out the vibration of the cv joints until it gets too much ? Just a thought. The cv joints are those the complete "half shafts" that go from the transfer case to the front wheels ? Also, all people who have this problem all drive 4WD ?
Bert
Old 08-01-2005, 08:57 AM
airjam18 airjam18 is offline
Re: vibration
I've got the same problem.........I recently replaced my inner and outer tie rods with some Dana ones......then I had it aligned and it still does it.....I'm kinda leaning towards the CV's being shot......anybody know how to tell if those are bad??
Old 08-07-2005, 07:36 AM
Re: vibration
thanks for the info, i guess i should have stated my trucks are only 2 wheel drive.
Old 08-07-2005, 07:46 AM
Re: vibration
I had a customer suggest the flex-plate my be out of balance. any of you have that checked? and how would you do that?
Old 08-07-2005, 09:39 AM
Re: Re: vibration
What is this flex-plate and where is it located ? Mine is a 4WD truck.
It seems when the truck is loaded it almost disappears.
Bert
Old 08-07-2005, 10:06 AM
jethro_3's Avatar
jethro_3 jethro_3 is offline
Re: vibration
He is probably talking about the plate that connects the crank to the stall convertor. It is a plate. If that were the cause you would see the vibration at the same exact rpm's in any gear not just a speed. IS that what you see?
"The Sleeper" '05 6.0L VHO
Cam in and
Low 14's happening at the track
Check out my Ride
Old 08-07-2005, 10:40 AM
Re: Re: vibration
No, it's only between 'bout 50 and 65 mph, either in 3rd or OD.
Bert
Old 08-09-2005, 07:50 AM
slacker_53's Avatar
slacker_53 slacker_53 is offline
How about getting the driveshaft balanced, or at least checking the balance?
When I die, I want to die peacefully in my sleep, just like my grandfather................not yelling and screaming like the other people in his car!
http://www.geocities.com/tbuckit1/index.html
Old 08-12-2005, 03:48 PM
Trucks_n_Harleys Trucks_n_Harleys is offline
2000 ext cab does it as well...no fix found yet....Starts at 63 mph (most noticed vibration) and does it up to 90 with a slight decreasing up to 90...
Old 08-12-2005, 06:17 PM
01silverado1500 01silverado1500 is offline
Re: vibration
i have the same problem on my 01 2wd silverado mine does it between 50-80
