Old 07-23-2005, 08:43 AM
98vert6spd 98vert6spd is offline
99 silverado tough to start
just bought this truck
the old owner told me about this but i never realized just how bad it was
anyway
when i start it for the first timei nthe day it cranks for like 8-10 seconds before itll fire
then itll run like crap for about 10 seconds before it is idling ok
the idle has a very very slight bump to it i can feal occasionally almost liek a quick stumble
maybe its normal
if you shut it off and then immediately fire it right back up itll start right up
if you let it sit ffor say 10 min
it spins for 10 seconds before it fires
If you put the key in and turn it to on but not start and let it sit for maybe 15 seconds it seems to start easier
Im thinking maybe thats allowing the fuel pump to prime or something like that?
anyway I was going to go up and buy a fuel filter today and see what that does
anyone else have any ideas
oh its got 106k on it and its a 4x4 automatic
Old 07-23-2005, 01:06 PM
ok well its not a fuel filter I just replaced that
the other was slightly harder to blow through but not clogged by any means
so i guess im on to the fuel pupm or pressure regulator
Old 07-24-2005, 08:27 PM
tallica_28's Avatar
tallica_28 tallica_28 is offline
Re: 99 silverado tough to start
Sounds to me like the Idle air control motor. My old mitsubishi mighty max did the same thing and turned out to be the idle air control motor. Looking in my repair manual the silverados have an idle air control valve. i would suggest getting a diagnostic first to tell you exactly what the problem could be.
Old 07-30-2005, 08:44 AM
ok guys heres the update
I think its fixed
it turns over 1 time and fires now
i replaced the fuel pressure regulator and the fuel filter
it took about 2 days to go away most likely because i ended up draing the fuel rail and it needed to fill it back up
but i beleive it is fixed
Old 08-31-2005, 12:25 PM
kingtchr kingtchr is offline
Re: Re: 99 silverado tough to start
Is your truck still running well? I am having the same trouble.
Old 09-01-2005, 09:10 AM
yea its fixed now
I thought i updated this post
about 2 days later the problem came back
so it was just a fluke that the fuel presure regulator fixed it
it ended up being my fuel pump
I bought one on Ebay for 150 shipped brand new
ac delco oem unit
and put it in
problem solved
really isnt that tough to put it in
I dropped the tank
if you have a place to put the gas, after you drop the tank drain it out and then reinstall it
itll be much easier to do then
Old 09-01-2005, 07:17 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
Originally Posted by 98vert6spd
yea its fixed now
ac delco oem unit
and put it in
problem solved
I dropped the tank
I have the SAME problem. Every one i know with the same model truck has the problem to. I replaced the fuel filter, spark plugs, clean throttle body. Did not fix it. But my check motor light would come on. I had a firend runa computer on it and that problem was the mass air flow sencer. Still have the starting problem after replacing that. I will replace the fuel pump now. THANX
