Old 07-23-2005, 03:04 AM
R-6 R-6 is offline
dash lights need help please
Hi everybody
I was driving home today when my dash lights went black.I tried adjusting it with the dimmer switch nothing happened.My head lights don't dim out or anything.My interior light is working all my lights work fine except for dash and speedo cluster.I own a 1993 honda civic hatch back Si
Old 07-26-2005, 12:25 AM
nfn13187 nfn13187 is offline
mine does the same I think it's a bad wire somewhere or the switch needs replaced every once in a while mine will kick on I read somewhere u can clean the switch off inside and that might fix it but am just going to look for a new switch and see if that helps
Old 07-26-2005, 12:31 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
Re: dash lights need help please
mine does it every now and then, my problem is the dimmer switch itself, i need a new one cuz something isnt making a good connection in there.
Old 07-26-2005, 12:52 PM
ZedEx's Avatar
ZedEx ZedEx is offline
GO-FIGHT-KILL!
Send a message via AIM to ZedEx
Same thing happened to my Blinkers and Hazards... New Hazard Switch did the trick. I think what Greenblurr93 said is correct, give that a whirl.
-Wes
-2000 PY Acura Integra Type-R #686 - WhoRe
-1997 EGP Honda Prelude Type-SH - Daily driver
R.I.P Hypsi87:Andy Filson
Old 07-27-2005, 02:14 PM
Shanda07 Shanda07 is offline
this jmight be your prob
Hi there
you might want to check the the fuse , that might eb the prob
Old 07-28-2005, 03:28 PM
polacek's Avatar
polacek polacek is offline
are your tail lights working? they are tied into the same fuse as the cluster.
Old 08-10-2005, 08:31 AM
typerx7 typerx7 is offline
the fuse fr the cluster and lights are seperate. try replacin the dimmer switch, thats the only power to the lights. if ur guages stop working its the reverse light fuse.
Old 08-11-2005, 12:35 AM
polacek's Avatar
The headlights are on their own fuse, but the taillights are on the same fuse as the cluster lights. How else would you know that your tails are not working (blown fuse) Dimmer switch to expensive. Start cheap and easy. Take a look at the schematic.
Old 08-17-2005, 10:40 AM
u can find a dimmer at a junkyard for 10 bucks if theyre stupid. if u figure ou thta tu need one ive got and extra ill ship to you. rip the dimmer swithc apart and check for continuity. check all fuses. look for burn marks on the back of the cluster. get back to me.
