Old 07-23-2005, 02:58 AM
spidereddie's Avatar
spidereddie spidereddie is offline
Send a message via AIM to spidereddie Send a message via Yahoo to spidereddie
S2K= Honda S 'Tune'thousand
Tamiya white version that comes with the mugen wheels and top.
Will tune this one out also. But will try to keep it a 'classy' tuner. After all this IS an S2K. Plans:
Full custom body kit from tamiya epoxy
Aoshima 19's (not sure which ones) with brembos'
Semi-conservative tuner decals
Gt-wing
FMIC
custom dual exhaust
Tach
A-pillar gauges/pods
Dash TV
Nos bottle
Photo etch racing pedals
Racing harness
2-tone interior
here's all I have so far. Just the body kit done
Side skirts.
Front lip
Rear taken from the custom revell thunderbird rear end dremeled and epoxy modified to fit
With first coat of primer to see where defects are
Well, I'm enjoying this quick dry epoxy more and more every time I use it....it's so simple
Ed-
Old 07-23-2005, 03:05 AM
Bas Carwash's Avatar
Bas Carwash Bas Carwash is offline
Re: S2K= Honda S 'Tune'thousand
Now how on earth did you do that? It looks absolutely flawless. Outstanding work
Old 07-23-2005, 04:57 AM
circuitR's Avatar
circuitR circuitR is offline
Re: Re: S2K= Honda S 'Tune'thousand
I reckon! At first I thought it was a resin kit. There must have been alot of filing and sanding.
Check out my
Instagram
Old 07-23-2005, 05:07 AM
Tikiman's Avatar
Tikiman Tikiman is offline
That is amazing. You should do a puttying tutorial i think. It looks perfect.
Old 07-23-2005, 07:30 AM
Big Kahuna Big Kahuna is offline
How did you make that body kit with Tamiya Epoxy putty?
Was there some sort of mold made first?
Looks great so far.
Old 07-23-2005, 09:07 AM
Bossolani Bossolani is offline
Very nice start!!!
Cesar Bossolani
www.scaleimportracer.com
Old 07-23-2005, 10:16 AM
MidMazar's Avatar
MidMazar MidMazar is offline
definetly looks like a resin kit, awesome job, please show us how you made those m3 skirts!!
In Progress
Old 07-23-2005, 10:19 AM
tonioseven's Avatar
I'm sure you'll make it a first-class project!!
Old 07-23-2005, 10:54 AM
g00eY's Avatar
g00eY g00eY is offline
good work so far!
Old 07-23-2005, 12:10 PM
Jeep_Rubicon's Avatar
Jeep_Rubicon Jeep_Rubicon is offline
Great so far.
Old 07-23-2005, 12:16 PM
D_LaMz's Avatar
D_LaMz D_LaMz is offline
Wow, great work!!
Old 07-23-2005, 12:57 PM
honda_racing101's Avatar
honda_racing101 honda_racing101 is offline
Send a message via AIM to honda_racing101 Send a message via MSN to honda_racing101 Send a message via Yahoo to honda_racing101
Excelent!
dSoc member #67
1995 Honda del Sol EG2 VTEC Milano Red. RIP :crook:
1994 Honda del Sol EG1 S-full VTEC conversion.
Buy my Del Sol parts!!
Old 07-23-2005, 01:10 PM
Apexi_N1 Apexi_N1 is offline
I like the front lip, remind me of the OEM lips!!! Looks great!
Old 07-23-2005, 01:38 PM
FocusOnCivic FocusOnCivic is offline
Send a message via AIM to FocusOnCivic
WOW!
That looks awesome! Your putty skills are supurb. I'll be on the look out for this one!
Old 07-23-2005, 01:55 PM
Wow! Thanks guys. To answer some questions
Yes i'm using tamiya quick dry epoxy. Not it's not a resin kit. No I didn't use a mold. The side skirts where done mostly with the dull side of a blade to make the sharp edges and a toothpick (notice the little bucket of them in the last couple of pics). I just globbed a bunch on and kept molding with my fingers first. Then I would keep rolling a toothpick over it to smooth it out. Then I'd use a toothpic again or any flat object to press down and mold the straight lines. The little 'indentations' towards the front of the skirts where done by taking a piece of styrene and just pressing it down into the putty.
Then I just started sanding with a 300 grit dremel drum. Then I used 220 grit paper and worked my up to 1000. I always attached my sandpaper to some flat object to allow me to make the lines crisp (toothpick, blade, piece of styrene, block etc)
Ed-
