Go Back   Automotive Forums Car Chat > Chevrolet > Nova
Old 07-22-2005, 09:42 PM
floaterboy floaterboy is offline
Send a message via AIM to floaterboy Send a message via Yahoo to floaterboy
Remove Tumbler
How do I remove the tumbler from the ignition switch in my '64 ChevyII?
Old 07-23-2005, 02:44 AM
72_supernova 72_supernova is offline
if its the same as my 72 then you have to take off the steering wheel, the turnsignal cam, it unplugs at the base of the steering column, and whatever else is in the way then there will be a single screw, 1/4", that holds it in, unscrew it and slide it out.
Old 07-23-2005, 04:39 AM
chevy3504 chevy3504 is offline
Re: Remove Tumbler
ok after you unplug wires and unscrew/unbolt anything holding it in there is a small hole on the face plate get a paper clip or somthing small and stickit in there while you turn the key play back and forth till it releases
