Old 07-22-2005, 09:34 PM
blk92sl blk92sl is offline
sleepy eyes?
ive noticed that some of you (like StealthModifier) have the sleepy eye headlights. did you use the "pivot" (http://www.pivotusa.com/accessories/pivrhu.htm)
headlight kit? and the only instructions ive seen are in japanese, how hard was it to install?
Old 07-23-2005, 09:38 AM
Zeiss's Avatar
Zeiss Zeiss is offline
http://www.3sxperformance.com/instal...ller/index.asp
tada
Bye V8...
Old 07-23-2005, 04:33 PM
oh that was easy, thanks
Old 07-23-2005, 08:11 PM
StealthModifier StealthModifier is offline
Re: sleepy eyes?
yea. actually i dont really have the conversion. i just use the knob to make it go up an look that way.
Old 07-24-2005, 01:01 AM
? what do you mean?
Old 07-24-2005, 03:52 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: sleepy eyes?
there's a knob for each headlight, just toward the center of the car next to each headlight. the knob has a rubber cover over it. the knob is actually red. turn the knob to adjust the level of the headlights.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 07-24-2005, 08:42 PM
Re: sleepy eyes?
yea. can also umplug the motor to the head light so that when u turn on the lights it will stay in that position. but i wouldnt drive at night like that.
