Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - Air Cooled > Type 1
Old 07-22-2005, 09:36 PM
Rick's69's Avatar
Rick's69 Rick's69 is offline
Send a message via AIM to Rick's69
I need brake help
I just bought a brand new master cylinder bled it and installed it. when i was bleeding the back brakes the pedal got harder and harder. as soon as i bled the fron passenger side drum brake the pedal lost all firmness. Can anyone tell me whats wrong? it has brand new brakes all around. and i dont see any leaks anywhere. please reply soon.
-Rick
Old 07-22-2005, 09:38 PM
mustang girl 2 mustang girl 2 is offline
Send a message via AIM to mustang girl 2 Send a message via MSN to mustang girl 2 Send a message via Yahoo to mustang girl 2
Check your brake line in the back first then if you need more help let me know!!!!!
Old 07-23-2005, 11:56 PM
Rick's69's Avatar
Re: I need brake help
i checked the lines and i dont see a single leak
Old 07-24-2005, 10:18 AM
BoatCop's Avatar
BoatCop BoatCop is offline
You're bleeding them in the wrong order. Start with the wheels closest to the MC and work your way out.
1. Bleed the MC
2. Left Front
3. Right front
4. Left rear
5. Right rear
Adjust the shoes and then bleed again.
If you don't do it in order, you can push air fromt the front to the rear, which is what I suspect happened in your case.
Alan
BoatCop
Old 07-24-2005, 11:15 AM
true.....that is so true you have to it that way or there will be problems...
Old 07-28-2005, 10:37 PM
Rick's69's Avatar
that was not the problem. i just replaced the front brake assembly with disk and opened all of the valves to let the fluid and air drip out not its better than ever. thanx anyways. i think the problem with the drums were the brake cylinders. later
Old 08-14-2005, 06:07 PM
Doug Rodrigues Doug Rodrigues is offline
Send a message via MSN to Doug Rodrigues
http://www.vw-resource.com/bleed2.html
This is the way we did it also when I was a VW dealership mechanic long, long ago.
Old 05-20-2012, 05:48 PM
brettstgermain brettstgermain is offline
I have an issue with my brakes too.. i have a 75 superbeetle.. bought it in va..drove it to new york.. no brakes..my issue is this...i replaced the master cylinder with the same as was in it when i got it.. assuming it was correct...I bled and bled and bled..trying every bleeding sequencei could find.. i have a official vw repair book.. and the bleeding sequence is different from what u guys say here..sooooo confusing. and no matter how i bleed i get no pedal.. go straight to floor..hoping someone can set me straight... now i did learn this much with this brake master... there are 2 different ones for the superbeetle in 75..the difference is the metering in the MC...and so when i get the new one im hoping to get the right sequence to bleed these brakes...HELP.! -brett
