Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 07-22-2005, 08:35 PM
badassfocus1101 badassfocus1101 is offline
Banned
Send a message via ICQ to badassfocus1101 Send a message via AIM to badassfocus1101 Send a message via Yahoo to badassfocus1101
wont start
juss bought that 7 i was talkin bout, we had it started like 20 times... towed it home today, had to start it to pull up on the trailor, and got it home to take off the trailor and the damn thing wont start... put new batt cable connectors on it and all i get is a click...any suggestions??? thanks
Old 07-22-2005, 11:31 PM
FDTT FDTT is offline
Re: wont start
dead battery
your alternarot was probably hooped and all the starts prior have drained the battery to the point of not being able to turn it over. Throw a set of jumper cables or a trickle charger on it and give it anothere go.
Dont drive faster than your angels can fly
Old 07-23-2005, 08:50 PM
Banned
wont start,
well i did! i put jumper cables on it, let it set forawhile n cranked it,,still nuthin,put a new batt in it, still nuthin,lights and windows work tho,me and my friend tried push starting it today....it tried, juss had no spark...
Old 07-23-2005, 10:12 PM
Re: wont start
Are you sure you have fuel in the tank? Not just the guage shows some, but have you put any in there? Change the plugs and wires, thow some ATF in there, start it up. Be prepared for some smoke tho :P
Old 07-24-2005, 12:59 PM
Banned
wont start
dude do u not understand or sumthin... gas has nuthin to do with my engine not crankin over....theres IS NO SPARK GETTIN TO THE COIL OR PLUGS.
Old 07-24-2005, 01:56 PM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
Re: wont start
is it flooded?
because that could foul the plugs.
RX-7 TII
Old 07-24-2005, 10:28 PM
Re: wont start,
Do you see the bolded section there my friend. This simple thing indicates that you have gotten the motor to turn over.
How did you come to the conclusion that there was no spark? How did you test this?
Pull out a multie meter and start checking things because from the sounds of it you have an electrical problem.
Old 07-25-2005, 01:13 AM
tubjub's Avatar
tubjub tubjub is offline
Send a message via ICQ to tubjub Send a message via AIM to tubjub Send a message via MSN to tubjub Send a message via Yahoo to tubjub
alright i'm going to settle this score... lol
what HAPPENED...
previous owner lost keys to car, so he took dashboard apart and pulled ignition switch from key tumbler assembly... used a screwdriver to start the car since it wasn't being driven, what happened is the switch itself malfunctioned and is "off-key" ... the spring-loaded postion that is suppose to have power supplied to fuel injection and ignition system, and activate starter to crank the car is now just the "on" position, so you hear shit clicking (relays and such) but the car won't crank because the switch won't go that far... the car did start and run perfectly fine up until the switch decided to take a shit... its a bit redneckish and or ghetto, but hey when a new assembly from mazda is $232 you have to improvise....
so for a temp. fix i located another ignition switch from a 87GLU and acquired it and gave it to the owner, no word as to whether it worked or not... will post pics when its back running again.
This is your life and its ending one minute at a time...
Old 07-25-2005, 01:16 AM
tubjub's Avatar
and on a LIGHTER note... wouldn't one of these be nice ????
the infamous R26B.... four rotors of fury
Old 07-25-2005, 03:41 PM
animalgonz666 animalgonz666 is offline
Send a message via Yahoo to animalgonz666
Re: wont start
what year is the car?
Old 07-27-2005, 12:50 AM
tubjub's Avatar
87 turboII
Old 07-28-2005, 02:52 PM
could it be the mass air flow sensor. and how did you check for spark? Are you getting spark at both primary and secondary coils.
