Old 07-22-2005, 06:35 PM
greenz71 greenz71 is offline
front end pop
i have 2000 silverado z71 and it makes a poppin noise ever now and then but mostly when im turnin. when it pops it fells like something hits my floor board. any advice or suggestions would be greatly appreciated.
Old 07-22-2005, 06:39 PM
BlenderWizard's Avatar
BlenderWizard BlenderWizard is offline
Send a message via AIM to BlenderWizard
Re: front end pop
Sounds like a CV joint to me...
"When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson
2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
Old 07-22-2005, 08:16 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: front end pop
possibly a ball joint or tierod end also
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 07-22-2005, 09:57 PM
Re: front end pop
Yeah, get under the truck and see if you have a cracked cv boot... if so, it's a cv joint.
Old 07-22-2005, 11:23 PM
Re: front end pop
had ball joints ant tie rod ends checked today both were fine.no cracks in cv joint boots
Old 07-24-2005, 05:07 PM
TXAGG05 TXAGG05 is offline
Mine did the same thing and it was a loose upper control arm!
Took a lot of moving the front end with a jack to figure it out.
Jeb
2002 Chevy Z71 Ext Cab, Black
2004 Blue Wave 180-V, 90hp Yamaha Outboard
Pre 1960 Duck Boat, 9hp Mercury Outboard
2002 Argo Conquest w/ tracks
Also driving, but not at my house:
2001 Pierce Saber
1989 Pierce Dash
(See Pics in my gallery)
Old 07-26-2005, 08:55 PM
Re: front end pop
figured out what was poppin in my front end. i had it in the shop couple weeks ago havin a front out put shaft seal put in my transfer case and when they put my front drive shaft back in they only put one retaining strap on my u joint and the pop was my u joint shiftin
2000 z71 escb k&n fipk tb spacer hyper tech programmer flowmaster exhaust flex-a-lite fans 3in body lift cranked torsion bars with ford keys super lift aal rancho 9000x shocks with in cab adjustment
315-75/16procomp mt
82 cj7 4in super lift springs with spring over up front 6in super lift spring in the back 36x12.50-15 super swamper tsl
94 mazda b2300 stock as you can get (gas saver)
if it wont go i dont need it
Old 07-27-2005, 04:28 PM
cflair1307 cflair1307 is offline
Popping in Front end
I have a 1995 K1500 and a pop developed today. I only get the pop when the gas is applied. It does not pop in neutral or an idle. The noise gets worse when turning. I have checked to see if any thing is visually wrong but am hoping someone can help.
Old 09-27-2005, 08:37 PM
akz71 akz71 is offline
Re: front end pop
check your cv boots for cracks, and when was the last time you changed the u-joints?
