HOW do you get the Ball joints out from the upper A-Arm?
I need to know how to remove the ball joint completly from the A-arm? I just got a new Ball Joint Camber kit from SPC and it says to press out the balljoint. All i have is a big machine press but i dont know were to press on the balljoint to get it to pop out. And do i need to rent a balljoint press from autozone or something?
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!
1989 civic DX with LS swap 94 B18B Engine Stage III Six Puck Clutch OBD-1 Conversion OBX Altenater pulley DC Sport Header Tsudo 2.5" catback exhaust Short throw shifter Apexi Rev/Speed Meter MUCH MORE TO COME! 1990 240sx w/ SR20DET SWAP COMING SOON! All Brand new inteior All body work is done 3" SR20Det downpipe Apexi N1 Catback Exhaust 3" 3" Test pipe Apexi Rev/speed meter |
Re: HOW do you get the Ball joints out from the upper A-Arm?
Your best bet, IMO is to bring it to a garage, they'll have all the right adapters and most won't charge more that $20 USD. GL
i believe there is a c clip that has to be removed then it shouldn't be a big deal to press it out if you got a press. i did it with the lower ball joints and they came out ok.( i used a hammer though)
stock b18a1 14.97 @ 92 mph |
umm... i thought on the civics/crx's the upper ball joint is part of the upper control arm and sold as a unit.
http://cgi.ebay.com/ebaymotors/ws/eB...spagename=WDVW Least this is the way i've seen them, except for the 1/2 degree ones that cost alot.
http://www.cardomain.com/memberpage/765867 |
Well in my hanes book it says the the upper A-arm balljoint is NOT removable. So why the hell did they say it will work for 89-91 civic/crx???? Is there a way to cut it out or something? Can i take a front A-Arm from a 92-95 civic and put it on my 4th gen or are they diffrent. Because the 92's have a removable ball joint.
Ok... I looked at a new set of upper control arms w/ ball joints I bought recently. On the underside of the controll arm there is a "C" clip. Looks like I'd have to take the ball joint boot off then the C clip and it might come out.
But like I said this is a new set, not OEM. So I can't say if the OEM is set up the same way.
the OEM ones are not removable, a lot of the replacement ones are though
