Go Back   Automotive Forums Car Chat > Hyundai > Tiburon | Tuscani
Old 07-22-2005, 01:32 PM
free2roamaz free2roamaz is offline
Send a message via AIM to free2roamaz
Ok, so any suggestions on what it would take to get my baby runnin <14 second 1/4? If at all possible, I would like to do it w/out the addition of Super/Turbocharger. Funds are a bit tight, but if the charger is the only way, then I will do it. I ask because I have recently been offered sponsorship if I can run my car 14 seconds or less. As of right now, I have CIA, 2 1/4" Cat w/Magnaflow Muff, STS, NGK Iridium. Appreciate any input.
Old 07-22-2005, 02:01 PM
BigTDawg BigTDawg is offline
Send a message via AIM to BigTDawg
you could go with new throttle body intake manifold and port and polish the head but i dont have a clue how much that stuff would cost. you would have to look intto that. and get some headers. msd ingnitoon system, i've been told thats the best. lighter flywheel maybe upgrade the clutch i dont really know how much the stock clutch can handle lighter rims
Old 07-22-2005, 05:44 PM
lowsonoma1999's Avatar
lowsonoma1999 lowsonoma1999 is offline
Authorized Vendor
Send a message via AIM to lowsonoma1999
Re: Gone in...14 Seconds?
Would help if we knew what year and which motor.
John Nance
Parts Manager
Terry Lee Hyundai
17665 Terry Lee Crossing
Noblesville, IN 46060
Old 07-22-2005, 09:41 PM
nisco nisco is offline
Tib Guy
Send a message via AIM to nisco Send a message via MSN to nisco
what is your current time....
port and polish everything, get some aggressive head work done
bbtb
get some nitrous... blah
then after all thats done, throw in a turbo charger, and youll be pretty set
almost that time
my sig made mommies cry, thats why i had to change it..
Old 07-22-2005, 11:04 PM
First off, I'm runnin my 01 Tib. 2.0L, i4. Right now im sitting at right above 16s average. (Course I do believe that the car can push out faster runs, but I just started into this whole racing thing back in Feb. Still learning.) Anyways, I have plans to add BBTB, Headers, Plug Wires, and do some weight reduction. Working on a way to take out the back seat, and put in a light weight seat length box for my Subs. Hopefully all within the next month or sooner. So basically I am looking to cut my time by about 2 seconds.
One thing I looked into is the ECU upgrade. Any takers want to show me where this can be found. Only ones I have come across are for the V6 Tibs, and the one or two I found for i4, were questionable to say the least. Thanx for the input. If I forgot to give you guys any info needed to help make suggestions, I apologize, so just let me know if you have any questions.
And Nisco, I know how you feel bout Nitrous, and I am right there with you. Screw that. I dont wanna be fast when I press a button. I wanna consistantly fly by.
Old 07-23-2005, 08:44 AM
Tib Guy
i would find some performance shops around you, or a place online that does porting and polishing.
and look into turbo kits, they can be expensive, but thatll definitely give you the best amount of power by far.
almost that time
Old 07-23-2005, 11:59 AM
dont get the bbtb if you are not planying on doning anything else to increase airflow cause you can only flow as much air as the smallest opening. if you go with the bbtb you need to do work on the intake manifold and head. got to an enigne shop see what they can do for you with balanceing the engine
Old 07-25-2005, 06:01 AM
Oh, I want as much air flow possible, eventually. But for now, could you set me in the direction of what I would change to compliment a BBTB, and where to find it perhaps.
I am still learning here, so I have a question. Based on what you said, wouldn't having a CIA be not completely pointless, but not nearly as efficent as if all the air flow components were modified, or am I lost out in left field?
As far as the port/polishing, any idea what the cost run, on average.
Old 07-25-2005, 07:12 AM
Tib Guy
Re: Re: Gone in...14 Seconds?
few hundread to a few grand, depending how aggressive you want your heads done, and what shop(s) you use
almost that time
Old 07-25-2005, 08:11 AM
speeddemonGtV6 speeddemonGtV6 is offline
Send a message via AIM to speeddemonGtV6
Why dont u want to go forced induction????
WANNA RACE?
Old 07-25-2005, 04:06 PM
yes, a CIA is not as efficent as if the all the intake parts were modified. the reason it helps with out moding the rest of intake system is because it is getting cooler air to the engine then if the stock intake was on
to get the most air flow you are gonna want to get a new intake manifold and port and polis the heads. as to where to find the manifold i found one website that had 1 for the tib and i dont remember what is was so when i find it again i'll let you know. 1 thing to remember when selecting the bbtb and intake manifold, is that the outlet end of the throttle body and the inlet end of the manifold are the same size hole. and if you cant make that work you can take one to a shop and get it bored out to match the other one.
for port/polish an eninge shop can probably do that for you.
where do you live?
Old 07-25-2005, 10:33 PM
where do you live?
I am down in Arizona, Phoenix/All Over.
As far as going FI...I plan on it. Just not right now. I am trying to build up speed with a few minor adjustments that will total around the cost of going FI if not less. Also leaves room for the shock factor, if I get lucky enough to grab this sponsor opportunity, then have them throw down for the FI costs.
Old 07-26-2005, 07:48 PM
your on the wrong side of the country if you were close to me i know someone who does port and polish
kspec has intake manifolds and keep us posted on how things are going i'll be doing the same thing as soon as i get my money back
Old 08-09-2005, 06:20 PM
Ok, so, I said I am working at this sponsor...well I didn't get it...yet. Did however get a call back from an application I put in a while back to Sports Compact Pro. Just waiting for them to draft up the contract to sponsor me for 10k$. Great call to get first thing in the morning. I am hoping that with that, I can put my car where I want it to be and grab up the one I have been working for as well.I will probably be buggin you all with more questions once I start getting things rolling.
One thing I am looking at is an engine swap. Might be hard, but would it be possible to fit a Nissan SR20DET S15 under the hood? Or if you have any other links for compatible engines that would be nice.
http://www.osakajdmmotors.com/intronissan.htm
Old 08-10-2005, 03:52 AM
Tib Guy
dont bother with engine swaps....
jus do more reaserch in turbo'ing your beta, trust me its a good platform and can take a beating....
theres enough support out there to get your RD into some real nice numbers....
almost that time
