Old 07-22-2005, 01:12 PM
DOCTORBILL's Avatar
DOCTORBILL DOCTORBILL is offline
Geo Metro Lover
Metro 3 cyl thermostat temp
I have a '93 Geo Metro 3 cylinder with 150,000 miles on it.
I found out that the default thermostat is a 195 deg type.
Would I prolong the engine life if I put a 180 deg thermostat
in that car?
It would lower the efficiency, but it would probably prolong
the engine lifespan by running it cooler - no?
Lower oil temp, less wear and tear on the hoses and it would
run cooler in the summer. I can always put a piece of cardboard
over the radiator in the winter.
DoctorBill
Old 09-13-2005, 10:42 AM
StephTho StephTho is offline
Usually the OE stuff is right on the money. Don't think a lower thermostat temp will make a difference. best way to go is keep your cooling system tuned up.
Old 11-01-2005, 07:39 PM
podling podling is offline
Re: Metro 3 cyl thermostat temp
To keep the really important parts of your engine cool (the exhaust valves) make sure your EGR system is working. It recycles CO2 into the intake manifold; CO2 does not support combustion, so the engine burns cooler.
Old 11-02-2005, 08:10 PM
mtbroadhurst mtbroadhurst is offline
My 95 1.0L 5sp uses a 180 degree thermostat. Never had a problem. I just replace them every 40K miles or so as a precaution.
I can't speak authoritatively about the 93s though, as 95 was the first year of a new model redesign.
I think you should use whatever temperature thermostat the specs require. A cooler tolerance will make the car run rich and, I believe, cause the ECM to run in a closed loop. Not good for fuel economy and emissions.
Mike
Old 11-03-2005, 07:44 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
engine will have less wear at 195 degrees. just stay with stock one.
