Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 07-22-2005, 12:20 PM
kuneeraj kuneeraj is offline
Hard shift of gears AT...please help
Hi
I have a 1997 Jetta GL, 2.0, AT, 94K miles.
Couple of months before I got the transmission fluid changed at the VW dealer. I believe they used the fluid drip method (not pressure flush).
Now the problem is that the gears (especially at 20 & 40 mph) take a looooong time to shift (RPM stays high (3000-3500)) and when it shifts it gives hard jerk.
Please suggest/advise on how to make shifting of gears SMOOTHER.
Old 07-22-2005, 12:31 PM
G-man422's Avatar
G-man422 G-man422 is offline
Re: Hard shift of gears AT...please help
Sound like they didnt put enough back in after they drained it.
Old 07-22-2005, 12:52 PM
Re: Re: Hard shift of gears AT...please help
but it happens only at 20 & 40 mph and not at 50 and higher speeds. I am not aware if there is a shift of gear at around 10mph.
Old 07-24-2005, 12:49 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
if the fluid level is even 1cup low it will shift hard. Also if the throttle body isnt adapted then it can shift rough.
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
