Obd 1 Codes?
Can someone list the OBD1 codes for me please.
I had a link for them, but it appears to be a dead link now. Thanks.. |
This is from page 6E3-A-21 in the 93 Lebabre/ Park Avenue Service Manual.(3800 VIN L)
OBDI Codes - * indicates MIL will light 13 Oxygen Sensor (O2S) open circuit * 14 ECT sensor high temp indicated * 15 ECT sensor low temp indicated * 16 System voltage high or low * 17 Spark reference circuit 18 Cam/Crank Error * 21 TPS voltage high * 22 TPS voltage low * 23 IAT sensor low temp indicated 24 Vehicle Speed sensor circuit * 25 IAT sensor high temp indicated 26 QDM "A" Circuit * 31 PRNDL Input Circuit 34 MAF sensor low gm.sec indicated * 36 Transaxle Shift problem 38 Brake inout circuit 39 TCC problem 41 Cam sensor circuit * 42 Ignition Control circuit * 43 Knock sensor * 44 Oxygen Sensor - lean exhaust indicated * 45 Oxygen Sensor - rich exhaust indicated * 51 PROM error * 53,54,55 EDR problem * 56 QDM "B" circuit * 58 PAS-Key II Fuel enable circuit 61 Cruise vent solenoid circuit 62 Cruise vacuum solenoid circuit 63 Cruise system problem (SPS indicated low) 65 Cruise Servo Position senspr (SPS) circuit (open / grounded) 66 Excessive A/C Cycling (low refrigerant charge) 67 Cruise control switches 68 Cruise system problem (SPS indicated high) 69 A/C Head Pressure Switch circuit 99 Power management |
Re: Obd 1 Codes?
"If everything seems under control, you're just not going fast enough." |
Re: Re: Obd 1 Codes?
GREAT. Thanks. They must have changed it a little.
Re: Obd 1 Codes?
This one is actually specifically for the 1993 Buick
http://autorepair.about.com/library/...l-dtcs-31a.htm |
Good look. Thanks |
Re: Obd 1 Codes?
I need two things. I have a 1995 Buick LaSabre. This car is OBDI compliant but with a OBDII 16-pin connector. First, I want to know which two pins I need to short to aquire the trouble codes. Second, Where can I find the definitions of what these codes mean? Information greatly appreciated. Thank you in advance!
