Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Street Bikes
Old 07-22-2005, 08:21 AM
sandhillv65 sandhillv65 is offline
Help Temp. Fan V65
Hi,I have a 1984 honda v/65 magna. I need to know how to wire up a toggle switch for my cooling fan. The fan works ok but i want to beable to turn it on with a toggle switch when im in town traffic before tempeture gets up high enough to kick it on. It has two wires that plug into radiator sensor, one is green one is black. It also has a wire to the thermastat and a ground wire going into bolt. Thanks for any info on this. Have A Great Day
Old 07-22-2005, 02:35 PM
chubster2003 chubster2003 is offline
Send a message via MSN to chubster2003 Send a message via Yahoo to chubster2003
Re: Help Temp. Fan V65
since the power wire's to the fan is on a sensor that auto kicks on the only way to make it work on ur command is to run a powered switch to it.. you will have to run a wire from your battery (fused) and to your switch then to the fan..
run the wire to the side that has power and presto
Life has its little suprises... and sometimes you with you could return them.
2006 CBR 600rr
1996 VW Golf GTI (2.slow)
1978 Chevy C-10 (350ci)
Old 07-22-2005, 03:20 PM
aussieidiot's Avatar
aussieidiot aussieidiot is offline
Gone crazy! Back soon
the best way to do it is to put the switch in parallel with the sensor. this will eliminate the back feed which can damage some sensors.
depending on the thermostat kind, most are a bi-metalic strip where heat makes the metal deform and bends to make contact with the power contact thus completing the circuit.
