Rubicon Unlimited lift with 35" tires
I am looking at buying the Rubicon Unlimited and need some advice on how big of tires that I can go and keep it safe as a daily driver. My buddy has a wrangler v6 5 speed wiht a skyjacker lifer and 33x12.50 BFG MT and I like it alot. I have driven it on the trails as well on the highway and it is what I would expect for a lifted jeep. The Unlimited has a longer wheel base and the Rubicon provides some beefier components like the axles as well as 4 wheel disc brakes and 4:10 gears. I will be getting the manual transmission. So far I like the Rubicon Express 5.5" long arm kit. Can I go to 35" tires and still keep it safe as a daily driver? Will the 35" tires with 4:10 gears on a Rubicon perform like my buddies 33" with 3:73 gears if both are v6 standards? Will the 4 wheel disc brakes on the Rubicon be enough of a brake upgrade to handle the 35's? You guys are a wealth of knowledge and I am hoping you can be my reality check. I don;t want to create a safety hazard as this is my daily driver on the freeways as well as weekend cruiser. I have waited many years to get this jeep and do it up right and plan on keeping it for probably 10 years as a daily driver. On that note with proper maintinence should I be able to get 200,000 miles out of a jeep?
Thanks, Todd |
Re: Rubicon Unlimited lift with 35" tires
I'm sure you know that any time you raise the center of gravity on a vehicle, the stability is reduced. It will be more prone to roll over in a rapid on road evasive manouver at speed. For me, that would make it a less desireable daily driver.
Also the big tires will reduce your braking capabilities on the road- no matter what equipment you start out with. Again - not a plus for a daily driver. Up grading the pads after you get it might help some but if you are off roading, slotted and drillled rotors are not a good idea and pads that require heat to completely activate the friction characteristics won't hold as well in some off road situations either. Every thing is a compromise and I guess it all depends what comprimises you can live with in a daily driver and what you want to do off road. I'm not trying to rain on your parade (even tho I might actually be doing that) but you asked for a reality check..... I like the lifts and tires as well as any one but I can't afford the limited use I would make of it right now. Your situation and use patterns are going to be different. The 35" tires and the 4.10 gears sound like a good compromise for street - just watch the radar unless you get the speedo corrected. So far as the 200K miles goes, there are lots of jeeps around with more miles than that. just my and I would love to have a Rubicon Unlimited too.......JD |
I have an '02 Wrangler X (I6, 5spd) with a 3'' suspension lift and 33'' x 12.5'' tires. All the gearing is stock. It pulls hard on the road... Unfortunately, the tires have compromised the stopping distance, and the lifted center of gravity makes the car feel a little unstable when turning a little fast or going over 70 - 75mph. ...I honestly think that I have the best possible compromise between a daily driver and an off-road machine. Keep in mind that these are Wranglers... you already have an advantage off-road. With a mild lift, some wide 33's with tires designed for your specific use, a limited slip or air locker, and some experience... you're set! (I'm still working on the experience part... until then, I need a winch for sure.
) My setup seems stable enough for an emergency lane change, too. Of course, this is all just my oppinion though. PM me if you want any specifics on my setup.
'98 Eclipse RS ENGINE: Twin Ceramic Ball Bearing T3/T4 with ceramic blades (20G for sale!), FMIC, 3'' Intercooler Piping and Down Pipe, Dump after Down Pipe, Walbro 255 FP, 450cc 4G63 Injectors, Greddy E-Manage, TurboXS DSBC (4/7psi for now). SUSPENSION: Sustec Front and Rear Lower Tie Bars, Suspension Techniques Front and Rear Sway Bars, DC Sports Front and Rear Upper Strut Tower Bars, Eibach Pro Kit Springs, KYB AGX Adjustable Struts, Polyurethane Bushings Everywhere. |
