Old 07-22-2005, 05:04 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Angry My tranny :(
So the other night me and a few friends were in my car driving on back roads at about 2am. We take this 15mph bend at about 40 or so with no problem. Well, actually the only problem was, right in the middle of the bend. Not one, not two, or three....or four....But a whole entire fucking family of coons were right in the middle of the road! So instead of going off-roading, i tag all of them. So anyway later on that night when i started heading towards my house, i kept smelling gear lube. Finally get home and park it. Look under my car to see my tranny leaking out all of my full synthetic 75w-90 gear lube! All over my driveway. There goes a good $40. I thought maybe it was from them damn coons. So earlier tonight i finally got around to pushing the car in the garage and taking a look. Jacker her up, went under and there was gear lube all over everything. Crossmember, both drive axles, oil pan, just about everything. So i got the idea to go buy some cheap-o gear lube at wal-mart to dump it in and see where it was leaking from. Took about 2 quarts until it started leaking. It's all leaking from the bellhousing. Right where the flywheel plate goes. I think my tranny just shit on me. Why would it be leaking from that spot? Any help would be great.
Old 07-22-2005, 08:48 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
Re: My tranny :(
Yeah i dont think raccoons would crack the bellhousing, have you hit anything else recently, like a rock or something? You had to have hit something, because bell housings dont just crack on their own without some help from foreign objects. I would just get it to a shop.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 07-22-2005, 09:43 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: My tranny :(
Well, at least now you have an excuse to drop in a LSD!!!
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 07-22-2005, 07:31 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: My tranny :(
If its coming from up in the bellhousing where you cant see, which I'm assuming is what you are saying (not an external crack that can be seen), I would suspect the intput shaft seal. I change them myself, but its an assload of work. Requires complete dissasenbly of the tranny, since its installed from the inside in Mitsu's infinite wisdom. No dissasembly of the shafts themselves, but everything has to be removed from the case all the way down to the bellhousing. If you drop the tranny it should be easy to tell if thats where its coming from. FWD trannies are super easy to remove at least...
Edit> I dont think I've seen this seal cause a huge leak, more of a slow thing that would take a couple days to drain. But its possible, espeically if the bearing went bad. The bad news is when the fluid level drops too low that seal/bearing is the first to run dry. I had a bad passenger side axle seal leak fluid and ruin that seal in a week tops.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 07-22-2005, 07:52 PM
macder macder is offline
Send a message via MSN to macder
Re: My tranny :(
Before my last transaxle failure occured, there where no warning sign's (non that I noticed). Then one day I'm driving allong in 4th gear @ 60Km/h (37.5mph), and all of a sudden my front wheels locked up, causing the car to come to a sudden halt(Talk about whiplash). My first though was my ball joint and/or tie-rod dis-connected, but everything was perfect. I knew had a severe transaxle failure when 4 men where unable to push the car in neutral(even with clutch disengaged). The thought of this occuring on the expressway at high speeds sends shivers down my spine.
1993 Eagle Talon ES (4g63NA)
14.6 @ 98 mph (110 octane race fuel)
-5 Speed Transmission (From a 4g67)
-Stage 2 Crane cams
-Ported and polished head
-Aggresive valve springs
-2.5" Custom made exhaust piping
-Custom header
-Gutted catalytic converter
-Bored 0.5mm
-Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC)
-2g valve lifters (Lifter noise returned, now it a true DSM)
-K&N w/modified air canister
Old 07-22-2005, 09:33 PM
wanaplay134 wanaplay134 is offline
Send a message via AIM to wanaplay134
Re: My tranny :(
hey steve do you have a 6 bolt or a 7 bolt i might be able to help you out if you want
Old 07-23-2005, 01:04 AM
Re: Re: My tranny :(
it's a 7 bolt
Old 07-23-2005, 09:02 AM
Re: My tranny :(
well let me call my dad then and see if that tranny from my cousins is still at his house and then you can have it. it probally needs cleaned and stuff cause its been there for like a year or so
Old 07-24-2005, 05:45 AM
Re: My tranny :(
well i found the problem everyone.....had the tranny out in about 2 hours.
yep, a nice size crack in the bellhousing....now my question is....how the hell did this happen!?!? coons couldn't have done this kind of damage. i still find it weird this all started after hitting them, though......
Old 07-25-2005, 09:17 PM
ned032002's Avatar
ned032002 ned032002 is offline
Wow...that is pretty
But hey on a happier note you now have a very large paper weight.
Do you have any idea what the hell caused that?
Old 07-26-2005, 05:06 PM
Re: My tranny :(
ok i was wondering if a tranny for a 90-94 FWD turbo would fit in my 97 spyder. here is the link for it...
http://cgi.ebay.com/ebaymotors/Eclip...QQcmdZViewItem
not sure if the ratios are the same or if the mounts are the same. thanks for the help.
Old 07-26-2005, 09:51 PM
Re: My tranny :(
it will only if it is a 93-94 from what ive been told thats the year they only had a 7 bolt anything earlier is a 6 bolt. that tranny my dad has is a 6 bolt but it is garbage anyway he says it is cracked in a couple places. hopefully i get my eclipse back from the shop soon its been there for 2 weeks now since the last time i seen you. i didnt have anywhere to work on it so i just took it somewhere. i cant wait 3 more weeks and i can move into my house
Old 07-27-2005, 10:14 AM
Gsx_hooptie Gsx_hooptie is offline
I don't know if it's the same for manual trannies, but there are several different versions of automatics that aren't interchangable. Also, I'm not sure if it's the same for manual trannies, but this is the coding system used on automatics (Mitsubishi):
1st number: F or W (Front/AWD)
2nd number: 3 or 4 (Number of speeds)
3rd number: A (Automatic) (M for manual?)
4th number: ## (Series of relative torque)
5th number: # (Version, design change)
(Above info from here, scroll to bottom: http://www.plymouthlaser.com/atfaqs.htm)
I suppose if it had the same code it would be the same. Then again, you could call Mitsu and they'd probably be helpful.
On another note, I'm impressed. That's a big hole. Hope you get it fixed up, good luck.
I used to own a DSM.
Originally Posted by Anon.
Capitalization is the difference between, "Helping your uncle Jack off a horse," and, "Helping your uncle jack off a horse." The comma is the difference between, "Eats shoots and leaves," and "Eats, shoots, and leaves."
Old 07-27-2005, 02:35 PM
AF - Advisor
Re: My tranny :(
The 91-94s are interchangeable, the 90s are wierd.
That hole was more than likely cause by a piece of gear tooth or similar getting in between the front diff and the case, then getting punted out because there is no room for extra parts in there. Very common failure. What could just be a gear replacement becomes much more involved becuase of the pieces floating around and doing more damage.
Edit> Just noticed the context of the 1g tranny conversation. You can't use any 1g trannies in a 2g. The 1g cars have the front and rear motor mounts on the block. The 2g puts them on the tranny. So with a 1g tranny you have no front/rear motor mounts.
Kevin Jewer
Old 07-27-2005, 09:45 PM
Re: My tranny :(
95 gsx racer are you sure about the mounts being on the block cause i just looked at my 93 and it didnt look like that to me
