Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 07-22-2005, 01:20 AM
joda1tyme joda1tyme is offline
Send a message via AIM to joda1tyme
95' V8 4.6L that stalls out when put into gear. Just started recently.
my car is a 95' t-bird, V8 4.6L and has just started acting up about two days ago. The engine idles fine in park and in neutral, but when i put into gear, it stalls out and sometimes dies. Even after i get it going, it will die as soon as i come to a complete stop. I just installed a brand new fuel filter on it, as well as replaced the spark plugs. I was told by one person that it has something to do with the electronical sensor just above the air filter casing? I don't know where to go from here and any reasonable advice would be much appreciated.
Old 07-22-2005, 02:34 AM
94tbirdlx2005 94tbirdlx2005 is offline
Send a message via Yahoo to 94tbirdlx2005
Re: 95' V8 4.6L that stalls out when put into gear. Just started recently.
I'm having the same problem. Apparently, no one is considering our thread, though. Jade and I have had a problem with this lately. We have tried all kinds of things, and still no help. Hopefully, someone will respond with something helpful... We'll see...
-Shifty
Old 07-22-2005, 01:54 PM
97Bird's Avatar
97Bird 97Bird is offline
Re: Re: 95' V8 4.6L that stalls out when put into gear. Just started recently.
-Shifty
I told you to have the codes checked and let us know what they are so don't say no one is considering your post! Jade replied but I didn't see anything from you. Oh, and checking your codes IS helpful!
Old 07-22-2005, 05:01 PM
The reason I didn't reply with the codes is because THERE ARE NONE. So apparently, IT'S NOT HELPFUL. Not to mention, when I tried to talk to anyone other than jade, my concerns were ignored. My "A few Tech. Questions" topic has been ignored as well. I tried to talk to you guys, but you have not talked back. I apologize if you feel that I haven't responded to you, but when there are no codes, what codes am I supposed to tell you about?
Old 07-26-2005, 01:17 PM
jade95 jade95 is offline
i got my car home had to dolly her there but shes home still not running i might ad but i borrowed my friends code checker and im sorry to say even after trying to turn her over she doent and shes got full power just no gas is going my dad thinks its my brain box but i think its my fuel pump. hes comin over tonight to see what he finds no spark its the brain box, spark its the fuel system(probably the pump. i'll keep you posted as to what goes down. other wise joda1tyme check out my posts as to what ive replaced i cant remember if i listed the fuel filter also but thats new too. sorry for bein' lengthy with this.
jade95
t-bird gurl
Old 07-26-2005, 01:20 PM
she wasnt runnin any codes before hand except for the alternator anyways
t-bird gurl
Old 07-26-2005, 10:13 PM
jerry96lt1 jerry96lt1 is offline
maybe the O2 sensor..
Old 07-28-2005, 12:35 AM
coondawg6 coondawg6 is offline
o2 wont keep from starting...i gave some suggestions in other thread relating to problem --no spark DOES NOT mean PCM--- possible but not probable. o2 sensor cause poor running but will not prevent from starting. no start main possibilities fuel supply, no spark, no compression in cylinders, timing events incorrect and thats it. each of those possibilities has their own cause(s).fuel supply could be bad pump, clogged filter, broken or restricted lines, fuse, relay or electrcal circuit to control pump. no spark could be crank sensor, cam sensor, PCM, fuses, relays, electrical control circuitry, ignition switch, coil packs, wires and few other improbable things.no/low compression- bad rings, stuck valves, blown head gasket(s), cracked head, or cracked block. timing events incorrect- timing chain broken, PCM , or bad cam or crank gears, misrouted spark plug wires. if you check all of these items you will find your problem. im betting on fuel supply problem. the other thread explains side of road redneck fuel pressure check. dont jump to conclusions it would suck to put fuel pump in to find bad relay or blown fuse just my
DONT EVER LEAVE WELL ENUFF ALONE , ITS BORING.
