Old 07-22-2005, 12:21 AM
honea4U honea4U is offline
Send a message via Yahoo to honea4U
Unhappy Knock Senosr
Ok, we have a "dumb blonde" in need of technical assistance....recently the "service engine soon" light came on in my 2001....knowing that it had to mean there was a malfunction, I took it to the local Auto Zone to have it tested.....found out that the "knock sensor" is testing low voltage....now not knowing exactly what that means....the man kindly told me that the problem was "not serious"...; however the light being on all the time drives me insane...as I am a female with a broken big truck....Is there anyone..that can please tell me where this "knock sensor" is located. I don't really want to take it to the chevy house...as I don't need another corn cob up my back side....so here are the spec's....2001 Chevy 1500HD 4X4....6.0 ltr V8 engine....I do hope that this is enough info...look forward to all the help!
Old 07-22-2005, 02:09 AM
chuck16's Avatar
chuck16 chuck16 is offline
Re: Knock Senosr
Dang, Are you sitting down for this one. I just read in my Haynes manual on how to replace those sensors and it sucks. Why would GM put them there?
You have to remove the Intake Manifold. The Knock Sensors are under the Manifold, pretty stupid hey. I can't imagine what a Stealership would charge for that job. I don't imagine it being too hard but, certainly not too fun...
I noticed the other day that my truck was occasionally pinging and was thinking about replacing the Knock Sensors. Think I'll just buy some different gas.
2008 GMC ACADIA
SLE Edition, 7 passenger model
I AM Canadian!!
Old 07-22-2005, 01:51 PM
mjgjr72 mjgjr72 is offline
Re: Knock Senosr
yup, have to take the intake manifold off and there are two of them under it, its about 5hrs labor so about 400 curnells in labor, depending on your local labor rate, not including cost of the sensors.
you can try posting on some boards and see if there is a gearhead in your area that can help you out for cash
http://www.performancetrucks.net/forums/
http://www.fullsizechevy.com/
http://www.gmfullsize.com/
Old 07-23-2005, 01:20 AM
Re: Re: Knock Senosr
Now I am pulling my hair out!!! This is going to be a pain in the back side of a job to complete....I called the local Stealership and was told...that all trdcks have 2 knock sensors...(news to me...) 1 that is located under the intake manifold and 1 that is on the outside of the block near the starter....the charge for the "easy" one is $230.00 (labor) + $55.00 for the part + the cost of the antifreeze....the charge for the "difficult" on is $430.00 (labor) + $55.00 for the part + antifreeze....CAN SOMEONE PLEASE tell me what/where/how this is...Im confused...now I know why I am not mechanic for living.....
Old 07-23-2005, 01:34 AM
Re: Knock Senosr
I forgot to say THANKS for all the information...I wish I could catch one of you guys online .... patience is a virtue that I don't have )
Old 07-23-2005, 03:53 AM
Re: Knock Senosr
(some older chevy motors have one knock sensor over the starter)
your truck has 2 under the intake manifold, all 99-05 gen 3 engines, 4.8, 5.3, 6.0L, have 2 knock sensors under the intake manifold, the sensor over the starter is the crank position sensor.
Old 07-23-2005, 07:33 AM
JDFester JDFester is offline
For what its worth, my truck throws this code whenever it has been sitting a while without being driven, or has been used for towing a heavy trailer, or has been driven in hilly terrain; basically anytime I ask it to work harder than usual. In each instance, I put higher grade gas in ( I normally use 87 octane), and the problem clears within a tankful. The light will even go out on its own, but to clear it faster, have the autozone guy clear the codes after 150 or so miles of driving on the good gas.
Old 07-23-2005, 10:58 AM
Re: Knock Senosr
Thanks again for all the help...greatly appreciated.
Old 04-09-2006, 05:57 PM
jaxondes jaxondes is offline
Re: Knock Senosr
I'm getting the same code on my truck. Anyone else have this issue?
Old 04-10-2006, 08:07 AM
CRAWFM CRAWFM is offline
Re: Knock Senosr
had to replace mine, about 2 months ago. lucky i had extended warranty. a$500.00 JOB, cost me $50.00. i read that when you wash the engine, water collects around the knock sensors, and deteroriates them. GOOD JB GM !!!!!!!!!
Old 04-12-2006, 12:34 AM
Re: Knock Senosr
I have a code reader, and the code comes up whenever I read it. However, its not throwing the SES light, so I might not bother with it. It has two knock sensors anyway.
Old 04-13-2006, 12:50 AM
Re: Knock Senosr
Well it set off the SES light tonight, so I guess I'll change it next weekend.
Old 04-13-2006, 01:18 AM
AzSandSlinger AzSandSlinger is offline
Re: Knock Senosr
This happenned on my friends '01..
We were going to replace them but decided to at least try a "home remedy"...
He ran 2 tankfuls of Supreme/101 racegas mixture (IIRC, it was an 80/20 mix) and Redline gas treatment (a whole bottle each time)
Hasn't came back on yet.. a year later...
-Shane
Old 04-15-2006, 10:37 PM
ryanszpara's Avatar
ryanszpara ryanszpara is offline
Send a message via AIM to ryanszpara
Re: Knock Senosr
my truck pulled that code too.....my auto teacher said its common, not a big deal. sure enough it went out like a week later.......
2002 Chevy Silverado
5.3 L v-8 4x4
Bought on 10-26-04
K & N Filter
4 Headlight mod
Fog Lights
FM 40 Series-dual turn downs
FUTURE PLANS:
3 inch lift
285/75 r16 BFG A/T s
Wheels? (american racing)
Old 08-01-2006, 06:10 PM
eljones247 eljones247 is offline
Re: Knock Senosr
How can water collect UNDER the intake? Aren't the sensors in the lifter valley? I am getting this fault code now....
