Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 07-21-2005, 09:38 PM
chipzinger chipzinger is offline
jimmy front end noise
I have a 1998 GMC Jimmy SLT with 95,000 miles. Every now and then there is a noise coming from the front end passenger side like were rolling over the rumble strips, it only happens when we drive it seems on the expressway, when this happens I will pull over stop and take off again and it quits also while the truck was making this noise I put it in nuetral and the noise continues if that means anything... I cant duplicate the noise for my mechanic its been in three times already...
tie rod and wheel bearing relaced on drivers side already can any body help! Does it sound like a front end problem or transmission problem.
THANKS
Old 07-22-2005, 01:02 AM
1993 Jimmy 1993 Jimmy is offline
Send a message via Yahoo to 1993 Jimmy
Re: jimmy front end noise
If it is a 4x4 I heard that there is a plug on the front end that sometimes goes bad. The only bad thing is I don't rember where the plug is. Maybe it will show in the Chilton. Does it sound like the 4x4 is trying to engage?
Old 07-22-2005, 05:42 AM
It does sound like something is trying to engage, I do have a manual and I will try to find this plug you suggested.
Old 07-25-2005, 08:12 PM
96JimmySLE 96JimmySLE is offline
Check the vacume diaphram under the battery tray. Mine did the same thing. It drove me nuts. Also check all of the vacume lines in the area. Good luck.
'97 Expedition 4X4
'77 GMC High Sierra 4X4 8' bed 2 1/2 lift, powertrax front and rear posi,
Flowmaster exhaust. 4 bolt main 350.
Old 07-26-2005, 06:17 PM
I will give that a try, Thanks
Old 07-29-2005, 12:05 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
What kind of noise is it?
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 08-09-2005, 08:47 PM
dinsinger dinsinger is offline
I have a 99 jimmy and I had the same problem and I replaced shocks, ball joints and still no fix and finally I figured it out. Believe it or not it was the rubber cushions under the hood and the rubber seal under back of hood. One ruber was missing and the back seal was crimped so the hood was bouncing against metal from time to time making an awful clunking noise. I fixed that and problem no longer existed. Check it out it could be an easy fix.
