Old 07-21-2005, 07:47 PM
acbaer acbaer is offline
Service Tire Monitor on 04 Silverado Ext Cab
I have a 2004 Silverado Ext cab with about 10K miles on it. I have never touched the tires, wheels, tire pressure, etc. I have been thinking about rotating the tires, but that is about it. I have never put a wrench to lug nut.
I am suddenly getting a alert on my dash that says " Service Tire Monitor". I figured I should check my tire pressure and they all read about the same 30.5. I looked in the door jam and it said they should be at 35. I have since raised the pressure in all 4 tires to 35. The light is still on.
Does anyone know what this is trying to tell me? I have done a search on the forum for this message and do not see it. I dreed taking the truck to the dealer. Next time I buy a truck it will be at the dealer next door. I hate driving 15-20 miles to the dealer before I go to work then juggling rides and such. What a pain. I guess I'm spoiled living 1.5 miles from work.
Any help would be greatly appreciated.
acbaer
ACBAER
2004 Silverado Z71 Ext Cab
-5.3 V8
So far:
AIRAID InTake System
AutoPage 610 Remote Start w/locks
Line-X Liner over the Top
2001 Pointic Grand Am GT V6 Ram Air
Old 07-21-2005, 08:55 PM
Ape0r Ape0r is offline
Send a message via AIM to Ape0r
I'm not sure about your truck, but I assume it is the same as various cars that I have worked on. The system detects pressure loss based on variation in wheel speed due to change in radius. The system needs to be reset whenever you change your tire pressure. I assume based on the fact that you have a tire pressure 'monitor,' that you have the steering wheel controls, play around with those and see if it can be reset with them.
'04 Silverado 1500 4x4 5.3L 3.73 G80
Old 07-22-2005, 11:23 AM
twomorestrokes's Avatar
twomorestrokes twomorestrokes is offline
Re: Service Tire Monitor on 04 Silverado Ext Cab
I thought so too until recently. The older GM vehicles read through the speed sensors, but GM has moved to a system that uses a pressure sensor in each wheel at the base of the valve stem and sensors pick up their signals. I didn't believe it, so I asked my pals at the dealer and they confirmed. They had to show me bulletins on it before I fully bought it. Sorry, I don't know what to say about your light though.
Who would have thunk it? On these vehicles with the sensors, the sensors need to be swapped over when going to aftermarket wheels.
