Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-21-2005, 07:40 PM
zarata zarata is offline
Hubs won't lock?
95 z71 and when i throw it in 4 wheel drive low the light doesnt come on on the shifter case, and theres no dash light that says 4wd. The front driveshaft spins but when i try to climb a hill the only tires that spin are my rears and cant climb for ****. is there a trick to locking the hubs? i tried rolling it in at around 5 mph. or is there something wrong?
Old 07-25-2005, 09:47 AM
Jeremy-WI Jeremy-WI is offline
Re: Hubs won't lock?
Your front axle actuator is probably toast or you have a bad fuse. You should be able to find info on diagnosing the problem by searching this forum or the chevy c/k, suburban, and tahoe forum
Old 07-28-2005, 12:26 AM
well i looked at the fuses and noticed that there is a fuse for T case but there is no fuse in there. i tried sticking a fuse but it wouldnt stay in. am i suppose to have a t case fuse?
Old 08-04-2005, 05:37 PM
if you have the manual transfer case, you won't have a fuse for t-case, you should check for 12V at the front axle actuator plug when the transfer case is in 4X4, if you have power you probably need a new actuator
Old 02-25-2006, 06:26 PM
Greywolf0723 Greywolf0723 is offline
If you get a new accuator, get the upgrade. It uses a better accuator and a spacer. You will have to run one wire to a brown wire above the T-case. It took me about 30-45 minutes to do the install. I bought it at the dealer for about $100.
1996 Chevy Tahoe 4x4
Motor: 350 Vortec approx 300HP
Trans: GM 4L60E
14 bolt rear end
6" Procomp Suspension lift
3" Fab Tech body lift
35x12.5 Dunlop Mud Terrains
1998 GMC Sierra Ext. cab 4x4 Z-71
Motor: 350 Vortec
Trans: 4L60E
(Yup it's still stock)
