Go Back   Automotive Forums Car Chat > Ford > Bronco
Old 07-21-2005, 07:16 PM
GoodCitizen GoodCitizen is offline
Rear power window
the automatic switch does not work I can only move my window up or down with the key in the tailgate and it labors pretty hard. anybody have this problem ?? Suggestions??
Old 08-18-2005, 09:05 PM
J-Roc J-Roc is offline
Re: Rear power window
Replace the switch in the dash...
Old 10-04-2005, 01:31 PM
Guy Pringle Guy Pringle is offline
My rear window is slipping
Hope this is in the right thread. My rear window wasn't working. Checked wiring and fixed it. Was working with key only. Fuse seems fine, but dash switch not working. Now the window doesn't want to wind up, seems to be slipping. Any suggestions?
Old 10-16-2005, 08:20 AM
Fullyinvolved Fullyinvolved is offline
Sounds like you need to take the tailgate apart. check the motor, it might need replaced. Not a fun job, but it beats having a window that wont roll up.
Never argue with an idiot. They will bring you down to their level, and then beat you with experience
Old 10-17-2005, 01:33 PM
Thumbs up Re: Rear power window
Yeah, you're right, Fullyinvolved! I opened the motor and found that the nylon/plastic? outer gear which houses the smaller metal gear was stripped inside, so the metal gear was just spinning around. 'Coz I live in South Africa and it takes too long to get replacement parts, I fixed it by making small inserts that fit in the outer gear which prevent the metal gear from slipping. Working great! P.S. was the same problem as my side windows.
Old 11-02-2005, 05:40 PM
james p james p is offline
i have the same problem i was tolld that there is a ground problem and it needs to be rewired from the dash to the window motor. i havent tackled this just yet cuz i plan on re doing the motor then the interior.
Old 06-01-2008, 10:34 AM
newbre newbre is offline
What if the key wont work and the switch wont work
how do i get the window all the way up
Old 08-24-2008, 09:56 PM
linuus41 linuus41 is offline
Funny, I'm having the opposite problem with my 1990 Bronco -- the inside rear window switch works fine but nothing happens with the key in the tailgate door. Any ideas?
