| Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible. |
Turn Signals & Hazards not working - Please Help!
I have a 97 Eagle Talon esi, non-turbo. About a month ago my turn signals stopped working. I checked my lights and fuses - all was good, at that time my hazards still worked. My interior green arrows didn't work for the turn signals, but they did for the hazards. I took it to a Chrysler dealership. I told him I was pretty sure the turn signal switch was bad. 6 hours and $80 later they told me what I already knew. They did run some other electrical tests, what they did not sure, but no red flags. The switch was on backorder. I was on vacation at the time, so I waited to replace it. On my way home I realized that my hazards no longer worked outside or inside lights. Stupid dealership. I just recently went to another chrysler dealership and bought the turn signal switch. I replaced it thinking everything will be fine and dandy, but no luck. I still do not have turn signals outside or inside and no hazards. I have checked the obvious fuses and they look fine. Does anyone know what else could be wrong? I really don't want to go back to a dealership if they told me the wrong thing in the first place... I'll really be pissed off if I just spent $90 on a new switch if I didn't need one! Please help~
Re: Turn Signals & Hazards not working - Please Help!
All I can suggest is to make sure you've checked all of the fuses for those lights. It sounds like a blown fuse to me. Check both the in-cabin fuse box and the underhood fuse box.
1996 Eagle Talon |
The dealer could have disconnected a harness to the switch and/or the hazards.
95 GSX:FMIC, 6-bolt, evo 3 16g, 2600 act clutch, 1g bov (crushed), and a 3" turbo back exhaust, dsmlink, dks 272 cams, wideband 02, Coming soon 2.3L Stroker, 1mm oversized valves, crower sprigs. 91 TSI AWD auto, gm 3.5 maf, maft, fmic, emanage, profec e-01, 3" turbo bk exhaust +more little stuff. http://www.ratemydsm.com/member/ez1286/?member=ez1286
