Old 07-21-2005, 06:19 PM
justlearning justlearning is offline
Send a message via AIM to justlearning
alternator
after i get my headers i will want to intall a high amp alt. due to the drain i get from my large power amp for my subs. i will probably go w/ a 140 amp power master from summit unless u guys know of a better replacement for same or less $ thats around 100-105 at idle and about 140 or more cruising. my question is will i need to buy a special braket and new belt for this or will any major mods need to be made to get this to work other than a bigger power wire for it?
Old 07-21-2005, 06:23 PM
Re: alternator
oh and i have a 91 rs 305 but the motor is from either an 87 or 89 firebird 305 so its still post 87 block
Old 07-21-2005, 09:26 PM
Rally Sport's Avatar
Rally Sport Rally Sport is offline
Is eating.
Send a message via AIM to Rally Sport Send a message via MSN to Rally Sport
Why dont you just get a power converter? Seems cheaper and what you really should be looking for.
Old 07-21-2005, 09:37 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: alternator
uhh, he's not trying to run ac type electronics in his car, he's trying to stop the huge power drain that his amp causes everytime the bass hits.
anyway, you don't need a higher amp alternator unless you plan on running a second battery as well. All you should need is a capacitor.
Old 07-21-2005, 11:09 PM
yeah u got it geno ive got a 81000 d amp by mtx if any of you r familar w/ stereos and it puts out 1500 w rms at 1 ohm and ive personally seen it run 8 12s...now i know alot in here are not impressed but thats not what the post was bout just need some help cause even w/ a 5 farad compacitor i still get down low enough to cut off acc. at idle if i got it turned up too loud.
Old 07-22-2005, 07:25 AM
Genopsyde's Avatar
The President
Re: alternator
well if that's the case, then you want to get the 2 battery setup w/ the higher output alternator, i've seen these alternators on ebay so check there first. I know my buddy got his alternator thru the shop that installed his setup.
Old 07-22-2005, 06:17 PM
Re: alternator
yeah im hopin to get away w/ just a high amp alternator and the single battery set up but the single batter will either be a optima or a stinger deep cell so after these a$$ holes get the rear end right...long story...ill be able to get started on this right after headers go on.
