Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 07-21-2005, 06:50 PM
supra90bturbo supra90bturbo is offline
92 maxima ve5, strange starting problem
1992 maxima se ve30de 5spd
short story,
removed engine to fix broken exh mani studs
to fix leaks
and to clean up general engine bay
put engine in and now it wont run.
i removed egr, charcoal canister, and factory pcv system
the pcv is routed into a catch can and the charcoal canister is removed correctly.
my only question is, has anyone heard of such a problem where to actually have the car run on its own without spraying carb clean into the intake tract, you need to almost completely block the mass airflow sensor? and when i say block, it will only run with all but a .5" hole to breathe through....
also, could this have anything to do with the egr being deleted?
the problem could be very little, or very large...
but i think its just one of those stupid little things....
thanks for entertaining my first post.
kurt
fujimi 1989 Supra Turbo-A : project car
tamiya 1987 Soarer 3.0GT - donor car.
Old 07-22-2005, 03:05 AM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: 92 maxima ve5, strange starting problem
short story,
removed engine to fix broken ...
Too much air -or- toolittle gas:
- If its air leak, no way but take intake out and renew gaskets.
- If its Fuel pressure; bad filter, pump, or regulator...
