Go Back   Automotive Forums Car Chat > Chevrolet > Corvette
Corvette
Old 07-21-2005, 10:31 AM
browny browny is offline
Exclamation 71 corvette Question PLEASE HELP
I have a 71 corvette somebody please help. I need to know what the hell this gauge is for on my dash in the passengers seat . Its round and has a dial under neath it the gauge says "pleasur-lift" and also says Delco under neath it. I assume its factrory GM?? Also did 71's come with cruise control. I have the button for it on my turn signal knob I also need one where can i get one ??? and can i fit the new c6 rims on it ??? please somebody help did the 71 come with side pipes? sombody sais there froma 69 is that true??? was a car alarm available??? i have this too , it looks like a door lock but its at the back like a trunk lock??
thanks
Old 07-21-2005, 01:57 PM
Glasact Glasact is offline
71 Corvette Question
Hi, I'll help you with what I can. The "pleasur-lift gauge must be an after market add-on of some kind. Definately NOT an option in "71". Your "71" did not have cruise control available. This was first available as a option in "77" as RPO K30. You could scab the parts at a salvage yard and make it look like original to most people, but early GM cruise was very unrelyable at best and is nearly impossibly to get any service parts for today. You could add after market cruise if your not concerned with keeping it original. C6 rims would fit the lug pattern only with adapters and you would have serious interference problems with your wheel openings. Consider a different choice. Your "71" did not have RPO N14 "Side Mount Exhaust System". Was last used in 1969. An alarm was available as RPO UA6 in 1971 and it looked like a keyed trunk release lock centered in the rear. Good Luck with your Vette!
Old 09-17-2005, 07:37 PM
sub006 sub006 is offline
Re: 71 corvette Question PLEASE HELP
Pleasur-Lifts are GM Delco air shocks primarily used for trailer towing.
Chevy DID offer hitches and other trailer equipment designed for 'vettes through dealer parts departments. I recall that Pleasur-Lifts WERE available for Stingray fitments, you probably have a universal air presssure gauge that could be added inline on Caprice wagons, pick-ups, etc.
Look under the back bumpers, inside the rear wheel wells, etc. for one or two tire-type valves and small-diameter hose leading to the area of the rear shocks
