Old 07-21-2005, 04:52 AM
charlees91 charlees91 is offline
Thumbs up rear noise
hey wats up to all i just found this site and, maybe i can ask acouple of questions, i have a 91 honda civic hb modl run geat about 197k miles, ivebeen hearing this clicking sound from the rear tire, i think is where the rear diferential conect to the body, looks like it has some sort of mount, click when i take off, before i bought the car i think it was lowered and it coused damege to the wheel housing, i really dont know im not really a mechanic but has anyone seen or experienced this, any advise will help thanks
Old 07-21-2005, 10:48 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: rear noise
1) FWD cars dont have rear differentials. 2) It would possably be a bushing (what your discribing as a mount) or it could be brakes or bearings. I'd do a visual inspection of everything, pop the brakes open and look inside for anything dangleing, jack it up and spin it and see if it still does it ect...
Old 07-21-2005, 10:32 PM
Re: Re: rear noise
as you can see i am not really mechanical savy, i had jus jacked up the car from the rear took off tire and i did not hear any noise, such as bearing but i did see that where the wheels connect to the body, there is some mount they look like arm of some sort and seem pretty worn would i have to change the whole piece or would i be abel to get jus the rubber bushing type rubber piece , i try to see who to take it off but it seem like a solid arm type, bolted to the bottom of the car
Old 07-21-2005, 10:39 PM
jestersrain's Avatar
jestersrain jestersrain is offline
Send a message via AIM to jestersrain
Re: rear noise
if its just a bushing its no sweat just unbolt the control arm from the frame and the bushing should just slide out
1991 HONDA CRX Si dead and gone you will be missed
Old 07-21-2005, 10:51 PM
Re: Re: rear noise
cool ill try that and hope it works, what do you think would be worse case sinerio, on this part would it be expensive .. by the way this site and the car are hardcore , all the car on here are the same but still unique in there own way thanks for your help.. charlee
Old 07-22-2005, 12:11 AM
Forunn Daberator
Re: rear noise
Bushings are a few bucks, but they wont just fall out and slide in- they'll have to be pressed in by a shop. Most alignment shops and such will charge you about $5 to press it in.
Old 07-22-2005, 12:17 AM
Re: rear noise
realy? that sucks when we did the urothane bushings on my friends 2000 eclipse the just slide in with a little dish soap
