Go Back   Automotive Forums Car Chat > Mitsubishi > Mirage
View Poll Results: how many of you mirage/summit/colt owners have water leakage in the trunk
yes, water leaks into my trunk too 6 54.55%
no, that's just a problem with your car 5 45.45%
Voters: 11. You may not vote on this poll
Old 07-21-2005, 02:16 AM
martinez205 martinez205 is offline
water in trunk
i have a 1995 mitsu mirage. water leaks into the trunk on rainy days. i've read in another forum some time ago that these 4th generation mirages had problems of this nature. so i would like to start a poll to see if any of you have the same problem.
Old 07-31-2005, 02:30 PM
gachrud gachrud is offline
Re: water in trunk
i have a 92 mirage and a 98 colt both leak heaps of water into the trunk. like a swimming pool in there...
Old 09-20-2005, 04:47 PM
Jim Johnson Jim Johnson is offline
Leaky Trunk
I have a 94 Colt with a leaky trunk. It's not real bad, so the easiest solution I found was to remove the round metal plug down in the spare tire well. Now the trunk stays dry because whatever water is coming in just drains right out.
Old 10-09-2005, 12:00 PM
richet richet is offline
Re: Leaky Trunk
i have a 91 mirage the problem was water leaking by the seal around the tail light (rh). remove and reseal with silicone. i had to do it twice.
Old 10-21-2005, 05:01 PM
akareh akareh is offline
Send a message via ICQ to akareh Send a message via MSN to akareh
Re: water in trunk
My 96 Mirage leaks a lot, i tried running a silicone bead along the rubber but that didn't help much. Did anyone else try something that worked?
Old 06-13-2006, 04:17 PM
Freezerboy69 Freezerboy69 is offline
Smile Re: water in trunk
Hi,
I also have a 1995 Mirage LS with leaky trunk. I found this forum by searching for a solution.
Also, my car has 59000 miles and seems to have developed a rear seal oil leak.
thanks!
