Old 07-20-2005, 10:49 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Cleaning out Cat
Guys - is there a way to clean out a catalytic converter? I've got one from a 3g4d that I'm working on that is blowing smoke - I swapped the cat with the other one I had and it's not doing it any more. So is there a way to clean out the bad one, or is it just pretty much shot?
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 07-20-2005, 11:35 PM
g-ride-si's Avatar
g-ride-si g-ride-si is offline
Re: Cleaning out Cat
ya u can beat it until its hollow or just get another one
Old 07-21-2005, 01:15 AM
jestersrain's Avatar
jestersrain jestersrain is offline
Send a message via AIM to jestersrain
or do like me and cut the sum bitch out and weld in a piece of 2 1/2in piping
Old 07-21-2005, 07:51 AM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
i gonna be gutting out my cat by ramming a crowbar in there acouple times then rev the shit outta my engine and repete till empty.
Old 07-21-2005, 07:52 AM
turtlecrxsi's Avatar
turtlecrxsi turtlecrxsi is offline
Send a message via AIM to turtlecrxsi
Re: Re: Cleaning out Cat
Why don't you just unbolt it and bench gut it then bolt it back up?
2008 KIA Spectra5 SX
2010 Honda CR-V EX
Old 07-21-2005, 09:56 AM
91civicDXdude's Avatar
a gutted cat is worse for exhaust flow than a stock cat. the reason being that it promotes flow stagnation. the chamber gets bigger, letting exhaust slow down & cool down, then it gets smaller.... trying to push cooler air into a more confined space means it will actually move slower than warmer air, so you basically just created a nice restriction for your exhaust.
either leave it stock or replace it with a test pipe.
Old 07-21-2005, 10:27 AM
Does a high flow cat have more baffles to streamline the flow?
2010 Honda CR-V EX
Old 07-21-2005, 10:33 AM
91CRXTC's Avatar
ok then ill get an over sized cat and gut that, then run a 2.5" pipe through that making a cat looking test pipe or a test piped cat so cops cant bust my balls.
Old 07-21-2005, 10:55 AM
Why don't you just get a high flow cat? it'll weigh less and be legal...
2010 Honda CR-V EX
Old 07-21-2005, 06:50 PM
thats a great idea and one that i have used a couple of times. those "high flow cats" you see on ebay are definately not legal in a way, but sometimes you can fool motor vehicle inspection people. they are nothing but a glasspack.
i have seen actual "high flow cats", but they will still have the honey comb inside of the smaller shape... unless its very high dollar, it will more than likely be 'not-so-high-flow' as a smaller size denotes less area for the exhaust to pass through.
bottom line, if it has the honeycomb, its a real cat, if not, its a glass pack.
Old 07-22-2005, 07:46 AM
Re: Re: Re: Cleaning out Cat
I haven't looked inside mine, but I paid $200 for the high flow cat from a reputable local muffler shop... we don't have inspection here anyway...
2010 Honda CR-V EX
Old 07-22-2005, 02:59 PM
Twyztidmind Twyztidmind is offline
Send a message via AIM to Twyztidmind
I dont have inspection here so i just used a test pipe off ebay. But for one of my friends that didnt live here and he had inspections, I took his old cat gutted it out, then found a pipe that would fit in there and shoved it all the way threw, cut off the exces pipe on both sides, then welded all the way around. Turned out great and fooled the inspection guys. But this was on a Nissan and they have diffrent cats then honda.
1989 civic DX with LS swap
94 B18B Engine
Stage III Six Puck Clutch
OBD-1 Conversion
OBX Altenater pulley
DC Sport Header
Tsudo 2.5" catback exhaust
Short throw shifter
Apexi Rev/Speed Meter
MUCH MORE TO COME!
1990 240sx w/ SR20DET SWAP COMING SOON!
All Brand new inteior
All body work is done
3" SR20Det downpipe
Apexi N1 Catback Exhaust 3"
3" Test pipe
Apexi Rev/speed meter
