Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-20-2005, 10:25 PM
LAWOMAN11177 LAWOMAN11177 is offline
Angry 99 eclipse gs.. no power
Hi All!! Please Help If You Can. I Have A 99 Eclipse. Aprox 64,000miles. About 6 Months Ago I Had To Take My Car Off The Road For Financial Reason, Got Addicted To Hooking It Up I Guess. Anyway The Point That I Need Help With Is Well, The Dope That I Am Didnt Regularlly Start The Car Like I Knew I Should Have. The Last Time That I Tried , I Could Tell That The Battery Was Dieing, All Lights Dimming Etc. Ugh. Anyway , I Tried Jumping It And Got No Where.. I Figured I Need A New Battery So I Got One And Put In In Today. Well I Tried To Start The Car And Nothing, No Lights Nothing.. Im Not A Car Guru But I Can Figure Out It Must Be A Power(electrical) Issue, I Have Read The Entire Manual And Nada. Did I Blow The Computer ? Is There A Main Power Fuse... Please If You Can Help I Want To Drive My Baby Again....obviously I Will Have A Mechanic Look At It But I Dont Want To Look Silly If It Is Something Simple.
Thanx....
Old 07-20-2005, 10:55 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 99 eclipse gs.. no power
Are you saying that nothing in the car works, no power at all?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-20-2005, 11:09 PM
Re: Re: 99 eclipse gs.. no power
YES IT IS SAD BUT TRUE. NOTHING AT ALL.. DO YOU HAVE AN IDEA WHY.
Old 07-21-2005, 11:58 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
What happens when you try to turn the key? Do any lights come on, clicking noises, can you roll the windows down if powered? Need more information as to what the car does when you try to start it.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 07-21-2005, 12:58 PM
Holset powered 420a
Check the connections on the battery to make sure it has a good connection, also make sure the ground going to the frame is good, no corrosion or anything like that.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 07-22-2005, 11:23 AM
Well i found to the battery cables connecters were ok attached to the battery but the part attached to the alternator was corroded.. i fixed and all is well. Finally able to get the pedal to the medal. Thanx all for you help. I really appreaciate it.
