Old 07-20-2005, 09:59 PM
Kat48462 Kat48462 is offline
Unhappy 1995 Cherokee fuse diagram
The taillights and plate lights are out. Guessing it's the fuse but I don't know which one! Can somebody out there with a fuse diagram help me please?
Thanks!
Old 07-20-2005, 10:52 PM
JDPascal JDPascal is offline
Re: 1995 Cherokee fuse diagram
Welcome to AF - Kat48462
Must be the "no owners manual in the used car glovebox" syndrome.....
We'll try to help you........
If it's the fuse your front marker lites should be out as well.
I believe it's fuse #4 under the dash.
A 12 volt test lite is handy for checking the fuses - and cheap too..... The lite should glow on both ends of the fuse if it is good. Might have to turn the key on if there is no lite at all. Lite on one end - none on the other - fuse bad.
JD
Old 07-20-2005, 11:05 PM
Re: Re: 1995 Cherokee fuse diagram
You are right on the "used car syndrome." I'll check #4 but my front markers are not out. Can't find my test lite.
Thanks for your help.
