Old 07-20-2005, 08:19 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
This has got to be a fuel problem
Everytime I get off work, I have to travel down a hill, pass the guard house and then get on the main road. Well for about a year now every time I go down that hill and when I stop at the bottom to signal onto the road, the car's rpms will go up and down on my tach. It goes from about 800 to about 200, doing it back and forth. Sometimes, it almost dies on me. Well today, right when It happened, I got out of my car and opened up the hood really fast and a gas smell just started to come from the car. I looked at the engine in around the manifold area especially to see if any fuel was leaking and I didn't see any. But then the gas smell started to go away. So I closed the hood and walked around to the back of the car and sure enough, there was the smell and much stronger. But I didn't see any leaks under the car. So I got back in and when I started to drive off, the car didn't want to go. Then suddenly it went and I squeeked my tires and the car started to bogg back and forth till it started to drive like normal. It was almost like riding a mechanical bull.
Well anyways, I drove home and started to look around on what could be the problem. I did take off the gas cap and something funny happened. There was no hisssing sound and the cap came off with no problem. The cap was surely screwed on tight but there was no pressure to fight against. So this makes me wonder, am I losing pressure somewhere or could I really have a fuel leak? Is there something I can replace to fix this? I'm so stumped right now.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 07-20-2005, 08:46 PM
4G4D Store's Avatar
4G4D Store 4G4D Store is offline
Send a message via ICQ to 4G4D Store Send a message via AIM to 4G4D Store Send a message via MSN to 4G4D Store Send a message via Yahoo to 4G4D Store
Re: This has got to be a fuel problem
How is your gas mileage? Also when you pulled your cap off today, how full was your tank? I would start by checking the seals for your injectors, fuel filter and fuel hoses for cracks.
1991 Sedan LX Auto (Auto2Manual / MPFI / OBD1 conversions complete)
www.naytontech.com :: youtube.com/naytontech
Old 07-21-2005, 04:17 PM
91CRXTC's Avatar
91CRXTC 91CRXTC is offline
Send a message via AIM to 91CRXTC
well my budy had a problem where the exhuast was hitting the gas tank and whore a hole in the corner of the tank. If you have a custom exhuast maybe its hitting the tank and u have a leak. By the way he also had no hiss when he opened the gas cap.
Old 07-22-2005, 09:15 PM
Shaguar47's Avatar
Last time I checked, I got about 39 mpg so that's okay. I looked around the entire manifold area and didn't see any leakage of gas or fluids anywhere. Is there anything that controls the pressure of the fuel on the manifold cause maybe it's leaking a vacuum or the pressure of the fuel. I don't know
Old 07-23-2005, 01:07 AM
Jos4DCivic's Avatar
Jos4DCivic Jos4DCivic is offline
Send a message via AIM to Jos4DCivic
Check your fuel pressure and also check regulator. check vacum line to regulator to see of maybe diaphram ripped and vacumm sucking fuel into intake.
Gl
91 Hatch SI
Heart of my Baby - DOHC ZC - Si tranny - PG7
Finally painted!!!
Old 07-23-2005, 07:47 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Yeah what jos said. You almost might want to drop the tank, I had a car that the tank was rusted though at the top, so when it was sitting on flat pavment it didnt leak, but when you went up or down a hill it would leak. Also look and see how the seal is on that gas cap - I had another car that the seal on the cap dried out and caused a sensor to read wrong (forget what it was... one of those piss off ones).
Old 07-23-2005, 10:45 AM
Smoghog Smoghog is offline
Gl
I agree with you Jos The gas tank would not cause a stall.
When you decelerate it causes the highest vacuum in the intake manifold. Thus sucking the gas through a wimpy/leaking inj.
Your fuel pressure reg decreases fuel pressure with manifold vacuum increase. Because the fuel is getting help exiting the inj.
Check your fuel pres reg vac hose is it wet w/gas? Also if you have a means to apply a vacuum to the reg. will it hold pressure. Don't go over 15 in.Hg.
SH
