Old 07-20-2005, 07:53 PM
Speed Racer Speed Racer is offline
Track On A Car
wat exactly is the track on a car and wat does it do in terms of performance? is there any way to change this, or is just wat it is period? also is there any way to change the shafts on an awd to fit into a different car? just curious for this info and cant find it anywhere. peace.
The cause of all the corruption on the Earth, is due to man and his imperfection ; GREED!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old 07-21-2005, 01:33 AM
Gasoline Fumes Gasoline Fumes is offline
Track refers to the distance between the center of one wheel to the center of the other wheel on the same axle. In other words, the width of the axle. You can change it slightly by using wheels with a different offset. Wider is generally better, but can cause the tires to rub on the fenders.
Taking the AWD system from one car and putting it on another is possible, but is pretty close to building a car as far as work involved. Unless it's a front wheel drive Subaru, I've heard it's pretty easy to convert them to AWD.
My Website
