Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 07-20-2005, 07:18 PM
mike65648 mike65648 is offline
2001 impala overheaing probelm
I have a 2001 impala that has been getting hot. This only happens with the a/c running while in traffic. Once out on the highway, with the a/c on...i have no problems. This has problem has worsened as the summer months get warmer. What is the problem??
thanks for the help!
Mike
Old 07-20-2005, 07:30 PM
thermal izod thermal izod is offline
Re: 2001 impala overheaing probelm
have u checked ur cooling fans? one or both could be out, either that or the temp sensor that turns them on could be going bad...
Old 07-26-2005, 05:00 PM
the drivers side fan is out. how do i replace? does both fans come out as an assembly or can i just replace the one? what is the cost of the fan or fans if i cant buy just one?
thanks
mike
Old 07-26-2005, 06:20 PM
jhuckaby jhuckaby is offline
Send a message via AIM to jhuckaby
thanks
mike
You might ought to check your antifreeze. If the radiator is full of sludge, that is a contributing factor.
Old 07-27-2005, 07:26 PM
hmm....i am pretty sure it's a fan assembly, w/ both fans on it...u'd have to get w/ a parts supplier to get the needed parts...i'm not sure of what the price will be, but the install is NOT hard.
Old 07-28-2005, 11:34 AM
Mikey-Mike Mikey-Mike is offline
Send a message via AIM to Mikey-Mike Send a message via Yahoo to Mikey-Mike
I've had cars before that would start to run hotter then normal as the coolant got old. As soon as I changed the coolant everything was back to normal.
Old 07-30-2005, 07:46 PM
billyo69 billyo69 is offline
I went through the same bullshit pass side fan out .Got fan assembly from junk yard lasted 3 moths then same prob.I bought a new fan assembly on line $185 as you have to change both u cant do just one.Its been fine since.Check fuses each fan has its own fuse right fan and left fan.
