Old 07-20-2005, 07:08 PM
94tbirdlx2005 94tbirdlx2005 is offline
Send a message via Yahoo to 94tbirdlx2005
Loping Idle, Dies Occasionally
Ok, I'm sure this has been covered somewhere, but I couldn't find it. Here's the info, followed by the question...
Vehicle:
2001 Ford Escort 4-door
2.0L I-4
Belongs to: A Friend
Modifications: None (motor mounts replaced)
Symptoms:
Idle lopes, car occasionally dies in Reverse
Idle drops and sometimes dies at stoplights
Gearshift bulb blown (not a current concern)
Known Issues:
Left bank running High
Air filter dirty
Spark plugs somewhat corroded
Oil recently changed, and no debris reported
Have not checked vacuum hoses, as car runs well in drive
Known Pros:
MAF sensor clean
Air intake clean
Tranny perfect
Runs well under most conditions
Issues to be addressed:
Change Air filter
Change spark plugs/wires
If anyone can come up with more things that may be wrong, please let me know. The friend previously referred to is not majorly concerned with the car's performance, as it has been doing this for about a year and a half. She has recently run into some money with which to repair the vehicle. I suggested that checking the computer codes was pointless, considering it seems to be free of errors. However, if someone can come up with a reason the computer should be checked, let me know. Also, please give any input that would help her situation. Thanks...
-Shifty
Old 07-20-2005, 09:31 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: Loping Idle, Dies Occasionally
Vehicle:
2.0L I-4
Symptoms:
Known Issues:
Air filter dirty
Known Pros:
MAF sensor clean
Air intake clean
Tranny perfect
Change Air filter
-Shifty
you answered your own question really plug wires alone can cause your problems you mention
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 07-21-2005, 05:48 AM
GTP Dad GTP Dad is offline
Pontiac Guy
You may also want to consider cleaning the throttle body and the IAC motor. Should smooth out the idle.
Old 07-21-2005, 08:57 AM
Thank you GTP Dad, will keep that in mind tomorrow, when I go to service it.
Old 07-21-2005, 02:06 PM
UPDATE
Today, we gave the car a tune-up. Here's the list of things we did... Prepare to be boggled:
New spark plugs/wires
Removed, stripped, cleaned, and rebuilt engine
Cleaned air intake
Cleaned fuel intake system
New air and fuel filters
Adjusted and fixed annoying throttle cable problem
Added fuel injector cleaner
New to-do list:
Clean EGR
Clean IAC motor
Flush tranny
Flush coolant
The problem is not as bad, but still there. We're not sure if the to-do list will help, but we're tryin anyway. If anyone can come up with more troubleshooting ideas, let me know.
Thanks,
-Shifty
Old 07-21-2005, 02:13 PM
jeffescortlx jeffescortlx is offline
Send a message via AIM to jeffescortlx
Re: Re: Loping Idle, Dies Occasionally
...Removed, stripped, cleaned, and rebuilt engine
Whoa?
Anyway's, it's usally caused by a vac leak. Could be from: Intake manifold gasket, injector O rings, throttle body, intake tube, or filter housing. The plug that is around the MAF wires must be in place, if not that will cause a leak. Or the MAF it's self could be bad also.
I make slow Escorts less-slow.
My cardomain
Old 07-21-2005, 02:48 PM
We checked the vacuum hoses before we rebuilt it. As far as the reason behind the rebuild, it has about 40k miles on it, and is already losin' power and mileage, plus it had been ran low on oil before she bought it, so the engine had a bit of carbon and other burnt crap on the inside. Haven't actually tested the MAF, how would one do that anyway?
-Shifty
Old 07-21-2005, 08:12 PM
Wollf's Avatar
Wollf Wollf is offline
You rebuilt engine after only 40k ?
Might be a resistance test for MAF in a repair manual, but as others say i would replace it instead. Seems you have done everything else....
I work as a partsman in the BC Area if you need help finding something you cant find pm me here and i will see what i can do. www.lordco.com
Better to sit in silence and be thought stupid , then to open your mouth and remove all doubt.
Old 07-22-2005, 10:33 AM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
My 1.9L was doing that. Recently put in a new 02 sensor and PCV valve and it stopped doing it. Don't know which was causing it but it's fixed!
Nevada Tumbleweed
Old 07-22-2005, 11:52 AM
PCV VALVE! THAT'S WHAT I COULDN'T REMEMBER TO REPLACE! Off to the garage...
