Old 07-20-2005, 06:50 PM
Smoghog Smoghog is offline
Question Timing issue...
Well where to start?
88 CRX Si
Dist has been replaced w/oem and computer replaced
New cap and rotor (rotor is tight)
New NGK plugs
fat 10mm plug wires
Timing is supposed to be 18 +-2 w/timing connector jumpered. @750rpm
Problem is I can't turn the distributor any more to get it to 18 degrees
It is at 22degrees and is backfiring when off then on the gas.
Can the fat wires cause timing advance?
Anymore ideas on what else to check???
No, check engine light is not on and it works.
THX
SH
Old 07-20-2005, 07:41 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Timing issue...
Timing belt is probably a tooth or two off.
Old 07-21-2005, 10:51 AM
Re: Re: Timing issue...
Thanks SC
I checked the timing belt and it looks new but the dummy that changed it might of missed a tooth. No it wasn't me..
SH
Old 07-22-2005, 09:19 PM
Shaguar47's Avatar
Shaguar47 Shaguar47 is offline
Send a message via AIM to Shaguar47
Re: Timing issue...
That's funny cause my car has been running really rough after I replaced my dizzy. We timed it right though with the red dot but the car runs like shit. Maybe my belt skipped a tooth or something too. I've been told the car still has the original belt in it so I'm sure it needs replacing.
1990 Black Geo Storm - RIP -
1990 Blu metallic Std Hatch
1999 Milano Red Ex Coupe
Current -- Ex to Si. It's Overdone, but who gives a crap. I don't!
Old 07-23-2005, 10:33 AM
Re: Re: Re: Timing issue...
Originally Posted by Smoghog
Thanks SC
SH
Hit the nail on the head "BING" One tooth off, Also the belt is loose. The new Q is can I repl the spring for the tensioner w/o pulling the bottom cover, and should I repl the whole tensioner It is a metal gear.
Thanks again SC
BTW; Just went through the manual and.. The tensioner does not run with the spring involved. How U set the tension is loosen the tensioner bolt and slowly turn the crank counterclockwise only 1/2" and then retighten the bolt. DONE and gone SH
