Old 07-20-2005, 04:47 PM
500hpgrandprix 500hpgrandprix is offline
Send a message via AIM to 500hpgrandprix
rear mounted turbo
i have a 97 grand prix, i no its no firebird, btu i wanna see if i can put a rear mounted turbo in it, and i hear that alot of camaros and firebirds are starting to do it, so if u have any info on how hard , and expensive it might be, i would appreciate it if u could help me out a bit
Old 07-20-2005, 10:20 PM
Mr. Luos's Avatar
Mr. Luos Mr. Luos is offline
Firebird Guy
Re: rear mounted turbo
This probably wouldn't work for you as well as it works for the F-Body's.
I would honestly recommend the Grand Prix forums to see what people are doing for boost.
1999 Pontiac Trans Am WS.6 #1747
Stock'ish'
Old 07-21-2005, 09:47 AM
WarShrike's Avatar
WarShrike WarShrike is offline
Agreed. The best starter would be to find a GTP engine, lightly increase the boost with a pully or snout upgrade and then look at turbocharging. As the GTP engine can handle the boost alot better right off the bat.
If you're antsy to get your rocks off with the boost, here's a site to get you started.
3800 Performance
Other than that, I'd say hit up the Grand Prix forums.
2000 Pontiac Firebird
3800 Series II V6
Bone stock (for now)
Old 07-21-2005, 11:08 AM
Jm93's Avatar
Jm93 Jm93 is offline
Send a message via ICQ to Jm93 Send a message via AIM to Jm93 Send a message via MSN to Jm93 Send a message via Yahoo to Jm93
i have never used one, or seen one in use. but i hear they give you some hardcore lag.
http://members.cardomain.com/jm9301
It runs once more. Parked for winter.
Old 07-21-2005, 09:59 PM
Mr. Luos's Avatar
Firebird Guy
Re: Re: rear mounted turbo
Not on the LS1 cars at least.
They work GREAT for the LS1 F-Body.
Stock'ish'
Old 07-21-2005, 11:59 PM
Jm93's Avatar
well i saw a mag test one, and get really good results on an ls1. but someone i talked to who had one on an LT1 said it was super laggy, that he had to spool the shit out of it before taking off.
Old 07-22-2005, 12:20 AM
WarShrike's Avatar
Maybe a pressure leak along the line? Maybe something needs tweaking in the ECU region.
I'm thinking and rethinking a turbo design for my car, possibly going to be a pretty nutty design as I've been doing most of my research based on the European market (Bimmers mostly) and some of the Japan based race cars.
I know I couldn't get the quality build off such a tight budget compared to some of the stuff that I've looked at, but it gives really good inspiration for later...
3800 Series II V6
Old 07-22-2005, 04:27 PM
well i was on the squires site, http://www.ststurbo.com/home , and they said they have no lag, their turbos are designed dif, for the rear of the car, and will be at full spool before 3000 rpm. so im not worrired about lag
