Go Back   Automotive Forums Car Chat > Nissan > Sentra | 200SX (USDM FWD)
Old 07-20-2005, 04:46 PM
ProZach626's Avatar
ProZach626 ProZach626 is offline
Send a message via AIM to ProZach626
Wheel bearing??? Plz Help
About two months ago my back left wheel on my 03 Spec V was squeeking a lot. I looked at my break pads and they were pretty worn/pitted so I replaced both the pads and rotors with ceramic pads and drilled/slotted rotors. (All of this was professionally installed) Anyway, now the same wheel is making a slight metal on metal rubbing sound When I turn corners and it did a little before I got my new brakes, so I know those aren't the problem. Could it be a wheel bearing? If so... how expensive are these to replace at a shop? If it's too pricey, does anyone know if it's an easy do it yourself job? Need Input soon... before my wheel locks up. Also: The car has been dragging slightly to the left at high speeds... I have heard this can be related.
Old 07-25-2005, 03:25 PM
ProZach626's Avatar
Unhappy
really could use any for of input here
Old 07-27-2005, 03:49 AM
slideways...'s Avatar
slideways... slideways... is offline
Re: Wheel bearing??? Plz Help
hard to tell
jack up your car and try shifting the guilty wheel around. if you can move the wheel AT ALL(even a smidgeon) separate from the axle, then its a bearing
not too sure but...my friend's 2001 sentra SE did the same thing(but on the front wheel(s)), and it got crazy loud after a while, but a small front end collision later and it went away... not too sure but it may be a fault with the B15. my old b14 SE didnt do it at all and i drove that thing a LOT
doubt its the bearing
that makes more of a sound like sandy growling when it goes
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 07-29-2005, 02:08 AM
Mykozo's Avatar
Mykozo Mykozo is offline
I haven't the slightest, but check all your suspension bushings at that wheel. That's the only thing I can possibly think of. Slideways is right, a bad wheel bearing is more of a grindy, sandy noise.
Old 07-30-2005, 06:26 PM
ProZach626's Avatar
Re: Re: Wheel bearing??? Plz Help
Well... I was wrong. The more I payed attention, the more I narrowed it down to it making the noise in my front end when i turn right at slow to moderate speeds. Probably my left wheel. Any input about that???
Old 07-31-2005, 03:55 PM
Mykozo's Avatar
Re: Re: Re: Wheel bearing??? Plz Help
Axle.
2002 Sentra SE-R Spec V
1992 Acura Integra LS LS/VTEC in pieces in my garage
Old 07-31-2005, 06:47 PM
ProZach626's Avatar
Re: Re: Re: Re: Wheel bearing??? Plz Help
Originally Posted by Mykozo
Axle.
Really? What about cv joins/shaft? And how much is that to replace?
Old 07-31-2005, 09:48 PM
Mykozo's Avatar
Re: Re: Re: Re: Re: Wheel bearing??? Plz Help
C/V joints/shaft are parts of an axle assembly. You will need to buy the whole assembly when you replace it. I looked around at a couple online parts places, but couldn't find a price, lots of these places want you to call. I do know that most axles, if you bring the core back after you replace it, tend to run about 80-120 bucks. Since the Spec V doesn't have equal lenght axles, I'm gonna assume one is more expensive than the other. I don't know how hard it is on a Sentra (haven't had to replace one yet), but typically axle replacements aren't really that tough of a job, if you have the proper tools. Dealer or shop will prob charge about 60-80 bucks to put it in if you want to go that route.
Old 08-01-2005, 04:52 PM
ProZach626's Avatar
Re: Re: Re: Re: Re: Re: Wheel bearing??? Plz Help
Thanks a lot, man... getting it looked at next week
Old 08-10-2005, 06:35 PM
ProZach626's Avatar
Damn!
So NOW my car has been in the shop for two days because they can't find the problem! Anyone have ANY ideas or suggestions? God my car is a freaking lemon!
