Go Back   Automotive Forums Car Chat > Volkswagen > Beetle - New/New Beetle Convertible
Old 07-20-2005, 03:34 PM
kriskahn kriskahn is offline
Weird Starting Problem -Help
I have an '01 1.8ltr turbo that won't start.
When I turn the key all the electric comes on but it won't turn over. There was a buzzing coming from the engine so I pulled the right most fuse of the three on top of the battery and the buzzing stopped, then the car started fine. I continued to do this about once a week. The dealer I took it to replaced the ignition switch, but it started doing it again two weeks later. Last night I pulled the fuse and it still wouldn't start, so I tried drift starting it which didn't work, but after that attempt it started right up.
Is it the starter? Was the ignition switch a redundant replacement?
Thanks so much for the help
Kris
Old 07-20-2005, 07:58 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
could be starter... does it make a growling noise after starting?
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
Old 07-21-2005, 12:19 AM
Re: Weird Starting Problem -Help
Nope, starts up fine and behaves normally. It happened again this evening, so I pushed up and down on the front fender to shake up the engine compartment a bit and then it started.
Thanks for the reply
Old 07-24-2005, 12:29 PM
VDUBMAN
01 ignition cylinders dont go bad, so i think its problably related to either the starter or the battery. Check for loose connections on the battery terminals or the fuses on top of the battery.
Old 07-24-2005, 01:52 PM
Thanks. The part that got replaced was an ignition switch, I was told they go bad at about 80000 for some reason. The car now won't start at all unless drift started, so I'm pretty sure it is the starter.
