Old 07-20-2005, 01:49 PM
mn80228's Avatar
mn80228 mn80228 is offline
Polishing kit suggestions
I have been using the Micro-Mesh finishing kit for some time now, and love the results that I have been able to get in the end.
After a recent move however I have found that I am missing three of the cloths. Which leaves a rather sizable hole in the system.
My question is this....
Should I get the Soft-Touch pads instead of another polishing kit?
The grits look to be the same, and I would expect the same results, but is there advantages to the whole kit versus the smaller pads?
The pads are about 1/3 the price of another polishing kit.
I do all my finish polishing with Scratch-X now, so I don't really need the polish in the kit.
Anybody on here used both, and can make a recommendation for one or the other?
Thanks in advance for the great advice Ia m sure to get from everyone here.
-matt
Matts4LittleWheels.blogspot.com
Old 07-20-2005, 01:55 PM
mickbench's Avatar
mickbench mickbench is offline
I have a full polishing kit, and I've now moved to using scatch X in stead of the whole micro mesh kit.
I still use the 3200 and 4000 grits. But then I just move on to Tamiya Compounds and then finish with scatch X.
what cloths are you missing?
Old 07-20-2005, 02:04 PM
speedphreak speedphreak is offline
Re: Polishing kit suggestions
I have used a polishing kit by Black Gold. Works great. I follow the wetsanding with 3M fine grit rubbing compound then Meguire's cleaner wax. Sometimes I do a glaze, but its totally not needed if you don't want to do it.
-Chris
Old 07-20-2005, 04:02 PM
freakmech's Avatar
freakmech freakmech is offline
Send a message via AIM to freakmech
Model Car Garage sells a pack with just the clothes (3200-12000) for like $12. and you can just buy each grit individually ($3).
Friends dont let friends buy die-casts...
"If it can't run 24hrs., it aint sh!t...." -me
Old 07-20-2005, 04:17 PM
Veyron's Avatar
Veyron Veyron is offline
Whatever you do change out all your cloths at the same time, don't mix old ones and new ones...it'll mess up your polishing results.
