Old 07-20-2005, 12:33 PM
bionictony's Avatar
bionictony bionictony is offline
Send a message via AIM to bionictony
leaking distributor.. i need a part number.. and its not the o ring
hey all...
im leaking oil from the distributor. the valve cover gasket and the distributor side o ring gasket is a few weeks new. i was wondering if i could get the part number for the oil seal inside the distributor. it's located near the o ring but inside the housing. just wondering if anyone could give me that part number. i have taken out the distributor to replace the bearing so far and it runs like new. i've tried looking at the honda automotive parts but it doesn't seem to have it. i also called honda and they said they only sell it with the distributor housing. too expensive.
so if anyone has distributor spare parts, please take a look and give me the part number. with the part number i could go to kragen or pep boys or napa and get the seal. i don't want to take it apart to get the seal, put it together to drive to get it and take it apart to replace it. but if i need to i will.
Old 07-20-2005, 04:10 PM
havnfun328 havnfun328 is offline
Hey,
I replaced my cap/rotor, and found some oil inside the cap. Is this the o-ring, or internal seal like bionictony? The O-ring looks easy.
Old 07-21-2005, 12:07 PM
bionictony's Avatar
Re: leaking distributor.. i need a part number.. and its not the o ring
oil inside means that seal needs to be replaced... i replaced the o ring but it i don't think it needed replacing because there was no oil leak signs near the 3 prong base.
