Old 07-20-2005, 11:07 AM
sbaker sbaker is offline
91 caravan gauge/speedo/tach problem
Hello all,
I have seeen this problem described by others but have yet to see an answer. My 91 caravan's speedo, tach, fuel gauage work at times and then quit. Sometimes they will not work until after having started and running about 30 seconds. While driving it, it's like the power is being connected and disconnected to all the instrument panel. It will flicker on and off. I have retightened and cleaned the grounds at the battery and engine. I cannot find the ground at the kick panel. I also cleaned the connections at the BCM and the instrument cluster. Any help would be great.
Thanks,
Scott
Old 07-20-2005, 11:40 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: 93 caravan gauge/speedo/tach problem
You may have an internal problem with the BCM and it will probably need to be replaced. Check car-part.com for a wrecking yard in your area that may have one to fit your vehicle.
Old 07-20-2005, 11:44 AM
Ok thanks,I will check prices at various places on the BCM, any other suggestions would be helpful and appreciated.
Scott
Old 07-21-2005, 08:11 AM
Fixed my problem with a used BCM from a salvage yard for $35.00. Thank you GTP Dad for the info. Hope this will help someone else. The Dealer wants over $300.00 for a new BCM.
Scott
