Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 07-20-2005, 10:54 AM
tsi4444 tsi4444 is offline
16g install tips
Well im hoping to attempt my evo3 16g and fmic install this weekend. I was just wondering if you guys had any tips for the 16g install. Like weather or not to remove the exhaust manifold, drain oil and coolant, etc.
Thanks in advance
Justin
97 TSI AWD
Apexi N1
RRE Downpipe w/test pipe, K&N FIPK, RRE lightened flywheel, ACT 2600, New short block installed due to crankwalk,autometer sport comp boost gauge,type-s bov, brode uicp, Johnny race car fmic with custom piping, evo 3 16g
Soon to be purchased: DSM link, injectors, fuel pump
Old 07-20-2005, 01:15 PM
sganc4life_4 sganc4life_4 is offline
Send a message via AIM to sganc4life_4
Re: 16g install tips
Drain your oil and coolant because if you dont, it will spill out everywhere
Before you do anything, make sure you can get the bolts off your exhaust manifold...Because if you cant, then draining all that liquid wasnt very usefull and a big waste
Make sure to double, even triple check oil and coolant lines and dont boost right away, make sure theres no leaks
95 Eclipse GS-T
6 bolt built block - shooting for 450 hp..very doable
Currently:
A lot, check progression thread - updated 3/27/10
Estimated completion date:
Soon lol
Old 07-20-2005, 08:34 PM
TsiTalon9587 TsiTalon9587 is offline
Send a message via AIM to TsiTalon9587
Pull the MPI fuse and crank the engine over a bit to much sure you prime the turbo. Most important for a new turbo. Get new factory mitsu turbo bolts. Make sure that right after you drive it with the new turbo, you check the torque on the turbo bolts.
Torque everything correctly. As for the fmic. It's not all that difficult, you should do just fine.
Aaron B.
95 TSi DSMlink'ed Evo3'ed 6 bolt
52.7 1/4 second try
11.0 1/16th 2nd in league.
22.3 1/8th Ties league record.
6.6 55 meters
Old 07-20-2005, 08:42 PM
JoeWagon's Avatar
JoeWagon JoeWagon is offline
Banned
idle looking for leaks, drive around then look for leaks again. make your signature smaller.
Old 07-20-2005, 11:22 PM
ok thanks. Do u guys think it is neccessary to remove the exhaust manifold?
97 TSI AWD
Apexi N1
Old 07-20-2005, 11:52 PM
Killa_DSM's Avatar
Killa_DSM Killa_DSM is offline
No you do not have to remove the exhaust manifold. I hope you replace the stud with a bolt, so its easier to take the turbo off in the future.
"Life begins at 20psi"
97 Eclipse GST-X 5spd
PTE 5031e/pte 880cc/vr4 fuel pump/Devils Own Water injection 12gph nozzle/pre turbo meth injection/fmic 28x10.5x3.5/greddy type-s bov/12" K&N/FP intake/dsmlink/gm 3.3 bar/maft/blitz ebc/act 2600/act 6 puck/SS Clutch line/3" turboback.
Old 07-20-2005, 11:56 PM
Whathits14 Whathits14 is offline
You can do it without removing it, but its a pain in the ass...also, take your radiator fans off, lots more room, and def required if you don't take the mani off....when you do the piping make triple sure you clamp those damn things down...if you think you did it tight enough, tighten them down some more......when you drive the car with boost for the first time and you hear a loud boom, don't worry its probably just one of your pipes that blew off...
Need a GOOD 6-bolt engine?
http://www.totaljdm.com/?id=19334
'95 Talon Tsi
EVO III GT, supporting mods, not running
Brand new never opened, walbro 190LPH fuel pump for a 2g $65 shipped.
