Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 07-20-2005, 12:56 AM
adamcody adamcody is offline
Question Humming noise from front left and leaking floors
Hi, I have a 95 grand am se about a month ago I started to hear a humming noise from the front left side of the car, I thought it was my hub/bearing assembly I changed that what fun I had but after doing so it still makes the same noise. Can some one please tell me what it could be. And also I started to notice that my driver side floor and back passanger floor fills with water after I wash or drive in the rain is this the special features I get by buying a Grand am???
Old 07-20-2005, 10:57 AM
Ridenour's Avatar
Ridenour Ridenour is offline
GranddAmnit
Send a message via MSN to Ridenour
Re: Humming noise from front left and leaking floors
Welcome to the forum. Are you sure the humming is coming from the same exact hub?
As far as the water issue, it sounds like you have a blocked sunroof drain. This is a common issue. If you don't have a sunroof, then it's most likely bad weatherstripping on those doors, but my 1st guess would be a blocked sunroof drain.
Old 07-20-2005, 11:39 AM
Thanks for the reply so quick; when I’m driving or turning left only I can hear the same humming noise. Everybody has told me that it’s my wheel hub??? I’m woundering if it could be a bad strut? Who knows for sure. Thanks adam
Old 07-20-2005, 05:59 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
I doubt a strut would cause the problem. Humming could be caused by either a bad wheel bearing/hub assembly or a bad tire. Several different brands of tires are notorious for making noise, especially goodyear performance tires.
Old 10-18-2005, 09:33 AM
tyger12 tyger12 is offline
did you check if you have a hole in your rockers
Old 03-01-2007, 07:58 PM
typhoon1654 typhoon1654 is offline
I also had water on the floor of my 95 Grand AM GT, I figured out it was coming from the bottom of the windshield. The black cover over the bottom of the windshield has a bad seal. I also have a humming noise coming from the left side of the engine where the pulley system is. If anyone knows where the noise is coming from and how to fix it,
PLEASE HELP!!
From,
typhoon1654
Old 03-01-2007, 08:11 PM
xeroinfinity's Avatar
xeroinfinity xeroinfinity is offline
out saving the world
Welcome to AF typhoon1654.
Sorry but we try not to bring up threads older then 2-3months.
If you need help with something post your own thread/topic and someone will help you.
This is closed!
1999 Grand Am SS 3.4 OHV
Closed Thread
